Graphics Artifacts on initial boot
Discussion in 'Hardware' started by RotoSequence, 14 Jan 2005.
  1. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I just assembled a new PC, and I am getting artifacts as soon as we get past the MSI k8N Neo 2 platinum boot load screen. The Motherboard is an MSI K8N Neo2 Platinum, and the video card is an MSI GeForce 6800 GT. It looks like a truck has run over the onscreen text and its completely indesipherable; Im not sure wether this should be in Hardware and Overclocking or Graphics; mods, feel free to relocate this as you deem necessery :)
  2. RotoSequence
    6 Jan 2004
    Update: I tried a new video card, and there is no artifacting; what could be causing the artifacting on the MSI NX6800 GT256?
  3. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    frazzeled card?, and did you try reseating the card. or if you changes the hs on the card did you check that?
  4. RotoSequence
    6 Jan 2004
    The video card is completely stock, and has been reseated twice. Im going to try installing the mobo drivers before I try the video card again, so the next status update will be occuring then.
  5. Tim S
    Tim S OG
    8 Nov 2001
    it sounds like one of the fragment pipelines is damaged - get an RMA on the card. :)
  6. Solutions
    Solutions What's a Dremel?
    24 Jan 2005
    If your artifacts are showing in the BIOS or during POST then the problem isn't the video card drivers... They aren't loaded/used until you reach thew windows boot screen (welcome to winblows).
    It is either a bad card or some settings in the BIOS are pooched. If your overclocking your CPU then make sure you set the PCI bus speed @ 33MHz (or your AGP or PCIX bus speeds will be unstable). GL
  7. RotoSequence
    6 Jan 2004
    Well, the problem is solved; a replacement video card is now in the system and it works fine; the old one was DOA (what a waste of an NV-40 GPU :( )
