Windows Artifacts on youtube etc
Discussion in 'Tech Support' started by wst, 25 Jan 2012.
  1. wst
    wst Minimodder
    30 Aug 2009
    Basically, I get little purple artifacts on youtube, in localised areas (so they conform to the image that should be being displayed, only it's purple pixels. Eg. a video of a cliff would have purple up to the edge of the cliff and not in the sky, if the artifacts were there), where there shouldn't be purple.
    Computer is running nice and cool (sub 45C even after the odd game, which it runs perfectly with no artifacts or problems :/).
    Core i5-2500k
    Gigabyte Z68CP-UDP3P
    8GB Crucial Ballistix Ram
    XFX Radeon HD 6870 1GB (and latest version of Catalyst).
    OS: Win7 Home Premium 64-bit
    Morphological AA is off (caused problems with Windows Live Messenger), any more details wanted?
  2. rem337
    rem337 What's a Dremel?
    31 Aug 2010
    Is it only on Youtube itself? Any other sites or online videos showing them same problems?
    If so I'd just check your flash player is fully updated etc, other than that unfortunatley I have no idea! :eyebrow:
  3. Xye
    Xye What's a Dremel?
    21 Nov 2010
    Sounds like a driver issue, or something to do with the hardware acceleration for flash video's?
  4. Steelez
    Steelez Minimodder
    16 Jan 2004
    I've seen similar before and changing the quality of the video has fixed it, say from 360p to 480p. Haven't been able to pinpoint what is causing it though.
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    turn off hardware acceleration. If its not messing up you games then Its hard to believe your cards are crapping out, so i imagine its a quirky thing with driver and hardware acceleration. Dont really need hardware acceleration with a cpu like yours.
  6. wst
    wst Minimodder
    30 Aug 2009
    Turned off all of the accelerations in the 'Video' tab in Catalyst. Seems to have worked, I'll keep an eye open though on a more extensive set of tests (more youtube) and get back if there are any more problems. Thanks!
  7. wst
    wst Minimodder
    30 Aug 2009
    Bumping as the initial issue was solved and most of you will have moved on...
    Check out this tearing. Very weird. It's not on every page but it's always roughly in the same place... :/
    Disappears on page re-rendering. Even occurs when typing in these boxes...
  8. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Video issues and now direct2d issues... Which version of catalyst are you running?
  9. wst
    wst Minimodder
    30 Aug 2009
    Just checked for an update on Catalyst, was using 11.12, going to 12.1. Very odd, I only updated catalyst (well, installed it) on the 22nd, when I built the computer. I'll crack on with this update and edit this comment if it keeps being dodgy!
  10. PhoenixTank
    5 May 2010
    AMD's driver schedule has been a bit crazy lately.
    Another suggestion: see if these issues occur in IE, chrome and/or firefox too.
  11. wst
    wst Minimodder
    30 Aug 2009
    Artifacts appearing on youtube, iplayer, windows desktop, flickr, occasionally in game as well. Youtube shows blocky artifacts and purple vertical line artifacts. The others show the purple vertical line type.
    Raised a support ticket with XFX, may have to RMA it.
