Modding As good as a dremel?!
Discussion in 'Modding' started by NiHiLiST, 20 Aug 2002.
  1. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Is this rotary tool anywhere near as good as a Dremel?
    http://www.diy.com/bq/product/product.jhtml?PRODID=87385&CATID=62383&maxBullets=999
    It's mains powered, so it shouldn't be too weak. Adjustable RPM from 800-27000, which is a pretty good range for modding since it should be okay for metal and plastics.
    I won't be doing much heavy duty work or anything, mostly cutting aluminium, and grinding the edges of course. I don't want to spend much more than this on a tool I won't use much.
    Anyone have any experience with it?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I got one about the same price from Focus, it's fine for light work but there's a warning in the destructions not to use for more than 10 minutes at a time.
    You get what you pay for, but it's a lot cheaper than a tru-blu Dremel and does me. ;)
  3. NiHiLiST
    18 Aug 2001
    Hmm, sounds okay to me. How do you think it would fair with 2mm aluminium sheet (not anodised)? That's what I'll be working with on my latest project. Also I'll be cutting 4-5mm thick alu angle :)
  4. Seth
    Seth What's a Dremel?
    14 Mar 2002
    /me hugs his beloved Dremel
  5. NiHiLiST
    18 Aug 2001
    Hey cpemma, does this take Dremel accessories?
  6. j`w0n
    j`w0n What's a Dremel?
    17 Jul 2002
    I have a 35,000 max RPM Dremel...I don't know what you'll need to use all that power for. That B&Q one is alot cheaper and looks like it would be easier to hold...as long as it can take all the bit accessories.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    most rotary tools are the same and take the same accessories :)
  8. NiHiLiST
    18 Aug 2001
    Cool, I might get one then. But first I have to spend my cash on upgrading our hosting for phlux.co.uk. Broken our monthly bandwidth limit in 10 days :'(
  9. Telkman
    Telkman What's a Dremel?
    22 Apr 2002
    this is fat-arsed chieftec steel. used up about 20 normal cutting blades and 2 fibreglass on it. i reccomend u get some of the #426 diamond dremel blades.
    nice tool :)
    :blush: just realised they different :lol: well this cheapy ones good too :)
  10. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Yeah that tool isn't bad at all, I had one 'cause I desperately needed a dremel but B&Q were out of stock for like 3 months.
    I've recently sold it and bought a dremel now though, i love my dremel :D
  11. NiHiLiST
    18 Aug 2001
    Cool. I'll probably invest in one then.
  12. inder
    inder Mr.Modtown
    17 Jul 2002
    hope it was turned off! :D
    i had a B&D RTX tool for a day, it was good but i just returned it becuase i found i did not have the skill (well i suppose if i kept it, i could have practiced - used it for my GBA Afterburner mod though..)
    same one as above i think...
    [​IMG] [​IMG]
  13. Telkman
    22 Apr 2002
    indeed it is. and darn nice too :D
