News Asetek bring liquid cooling to laptops
Discussion in 'Article Discussion' started by brumgrunt, 23 Mar 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    Hey, as soon as it's affordable, count me in.
  3. towelie
    towelie How do I Internet!!
    1 Sep 2011
    Woah this is insane, the price will be massive though espically if alienware are to play a part.
    Interesting stuff though.
  4. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    I really don't see the advantage of a liquid cooler in a laptop; chiefly because of all Aseteks touted claims can be achieved by heatpipe/vapour chamber coolers. There's no reason why a laptop CPU/GPU can't share a heatsink or series of connected sinks. Exactly the same results as the liquid system only potentially more compact, uses no extra power, has a lower chance for mechanical failure and would be lighter (less fluid involved and no pump).
  5. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    liquid inside a laptop? what could possibly go wrong?!
    Than again, with the very fixed nature of laptop components you can easily have a solid, non-expiring fluid path removing almost all sources of potential leaks...
  6. west
    west What's a Dremel?
    3 Jun 2011
    JCBeastie advantage is _much_ faster liquid transfer over components along with _more_ water (the more water in the line the colder any given component will be).
  7. The Infamous Mr D
    The Infamous Mr D Minimodder
    11 Feb 2008
    I'm honestly astounded this is the first time that anyone has ever spoken about liquid cooling (a great thermal dissipation technology) in a small thermally challenged consumer-orientated environment (laptops).
    Seriously, this should have been done years ago!
  8. warejon9
    warejon9 What's a Dremel?
    20 Apr 2010
    That was quite a chunky laptop, and if there was a voltage increase, and extra power due to pump what is the battery life like?
  9. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    The main limitation is the amount of of radiators surface area and air flow over the radiators with the main advantage of desktop water cooling lying in the fact it can effectively distribute heat to a much larger radiator than pipes.
    Liquid cooling will actually infringe on that constraint due to being bulkier than a normal heat pipes
  10. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Wonder what effect on battery life will be.
  11. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    Goes without saying that this will need to be bombproof.
    Very niche market, but +1 to Asetek for innovation, if it works as the video states.
  12. themassau
    themassau What's a Dremel?
    23 Mar 2012
    if it is a low power pump then the battery life will shorten in idle situations but it might stay the same when it is at load because the chips will run cooler and run more efficient. don't forget forget that lcd screen use the most battery power.
  13. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I still have a clevo d900t (non functional) and the insides look very similar to that apart from the pump of course. Oh, if any one needs any parts for a d900t pm me, the thing is just sitting around gathering dust.
  14. rodeltt
    rodeltt What's a Dremel?
    12 Mar 2012
    The thought of a water cooled laptop horrifies me. It might be fine when new but a year or two on its just something else to go wrong, imagine a water leak on the motherboard - terminal! Plus what effects would air travel and the pressurization changes have in promoting a water leak.
  15. JCBeastie
    10 Nov 2005
    You are ultimately limited by the heat exchanger, and since this solution doesn't offer any more surface area compared to a traditional heatsink I fail to see the improvement. Heatpipe coolers have proven to be very efficient, since essentially they work under the same phase-change principles as say; a fridge. Liquid coolers have an advantage that they can transport heat to a larger radiator than you could sit on top of say, a CPU, hence greater cooling ability.
    All this soloution adds is bulk and greater chance of failure. I'm not convinced.
  16. rogerrabbits
    rogerrabbits What's a Dremel?
    24 May 2011
    I wonder if they will have some way to top up the liquid.
  17. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    There shouldn't be a need. It's the same principle as with the Corsair H series. It is a hermetically sealed environment so if you actually need to fill it up you have a bigger problem since it will be leaking somewhere!
  18. leslie
    leslie Just me!
    19 May 2009
    It has been done a few times before but never got very far. I beleive Lenovo tried it once, as did someone else.
  19. rogerrabbits
    24 May 2011
    Ahh nice. It would be good to start getting laptops that dont cook peoples testicles for a change :p Not that I would ever buy one, way too expensive for me. Maybe if I win the lotto some day.
  20. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Our local pub has liquid cooling, has had it for years.
Tags: Add Tags
