News Asetek launches compact liquid coolers
Discussion in 'Article Discussion' started by CardJoe, 1 Dec 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    Its a tick box thing.
    Throw in one of these and an OEM can charge another $500 because all of a sudden its a 'premium watercooled pwnage rig'
  3. DwarfKiller
    DwarfKiller What's a Dremel?
    25 Nov 2010
    "Do you think that factor-sealed systems"... factory-sealed maybe?
    Being 92mm seems odd to me, don't know what to think of it at the moment. More details please?
  4. Lord-Vale3
    1 Dec 2009
    They explained why its 92mm - so OEMs can fit it on smaller fan mounts
  5. Jasio
    Jasio Made in Canada
    27 Jun 2008
    That's a very decent looking Corsair... I mean Asetek ... I mean Corsair... I mean Cortek...
  6. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
    Agreed
    Most of these factory made setups are pretty crap, a good air cooler surpasses most of these style things let alone a good custom wc setup.
  7. Lazy_Amp
    Lazy_Amp Entry AMD Engineer
    17 Jul 2010
    When I heard 'Dual Fan', I thought it referred to a dual fan radiator, which I thought would be quite interesting for some sort High Performance slim/small box. But no, it's just going to be boring Push-Pull.
  8. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    As far as I understand, they will build a dual fan radiator version (i.e. not a push pull) I remember seeing a picture of it on another site, can't seem to remember where though.
  9. Lazy_Amp
    17 Jul 2010
    http://www.asetek.com/products/oem-standard-products/92mm-products/565lx.html
    Ah... you're absolutely right... might be useful then.
    They even have a workstation model: http://www.asetek.com/products/oem-standard-products/92mm-products/585lx.html
  10. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    This means we will see more small-form-factor performance pc's with closed loop water cooling (since most of today's desktop pc's come with 90mm fans)
  11. ninong
    ninong What's a Dremel?
    2 Dec 2010
    will the 2x92mm rad fit on the tj07 rear exhaust slots? for those who are too lazy to watercool their tj07s :)
  12. jrs77
    jrs77 Modder
    17 Feb 2006
    Corsair buys their coolers from Asetek and only slap a sticker on it. Asetek is the original manufacturer for all of these.
    With that said, I still prefer the 120mm-option H50 from Corsair.
Tags: Add Tags
