Scratch Build – In Progress Ash stealth mediacenter. Small PC hardwareupdate 13/6-10
Discussion in 'Project Logs' started by M.Ø.J, 20 Dec 2009.
Should i keep posting logs the way i do. Blurring what the build will end up looking?
  1. Yes, thats gonna be more exciting than knowing what to expect.
    29 vote(s)
    55.8%
  2. No, id rather have the whole design shown, so i know where every part is gonna be located.
    14 vote(s)
    26.9%
  3. Really dont care. Im just looking at pics, so i wouldnt know anyway.
    9 vote(s)
    17.3%
  1. M.Ø.J
    M.Ø.J Getting there!
    19 Dec 2009
    It will have no effect, talking of a period of 5 years. The reason i used aluminium and vener, plus MDF boards is exactly that. Massive wood dont like changes in temperature. The method i use with contact glue and vener doesnt care. Its a rarely used combination, but if any big company is watching this thread, its gonna be copied for sure.
    I can only say what i said before .
    This method rocks !
    Still, they nered to figure out the thinner \ glue respactables. LOVE It !!
  2. M.Ø.J
    19 Dec 2009
    Just a teaser:
    Looks like im gonna be updating the project log during the weekend.
  3. DeadP1xels
    30 Nov 2009
    awwwww :O
    This is coming along very nicely its one of those projects that you can't imagine what the final product is going to look like
  4. M.Ø.J
    19 Dec 2009
    Thanks DeadP1xels :)
    Its not really on purpose.
    As soon as i get my new wood i will hurry up on the cabinets for the mediacenter to be able to make a setup to show exactly what im doing.
  5. M.Ø.J
    19 Dec 2009
    Ash stealth Mediacenter - Part2:
    Continued from Ash stealth Mediacenter-Part1
    Making of the basics - The Front for the Mediacenter 1:
    Having the template for the motherboard done, i wanted to get started with the chassis for the "drawer".
    I remember having had used the dremel a lot to cut smaller straight lines with great succes when i was last modding some 7-9 years ago.
    But with 3mm thick aluminium. Hmmmm, dont really know what the hell i was thinking.
    I need heavier tools. Also its much faster using a drill to get a hole for the blade of the jigsaw go into then simply cutting close to your drawen lines.
    Afterwards it just needs some filing till your happy with the result.
    So starting by drilling holes.
    Next cutting close to the lines.
    Next i drilled the hole in the opposite end hoping the alu would release itself.
    However it does make more sense to drill all holes first. Then Do all your cuts.
    Doing the same process over again for access to the PS3.
    Time to file up all the stuff you didnt get with the jigsaw.
    Its quite a time consuming process, but the result will make it all worth it.
    So just keep filing till youre happy with the result.
    Im happy with this. Its not flawless, but it really doesnt matter, all i need is straight lines, since ( You guessed it ) its all gonna be covered with vener and wood.
    Stealth for the PS3:
    I dont want to be able to se the slot in for the PS3 blueray drive, but i need access to it offcourse. Also want to keep the warranty on it.
    Obvious thing was to do some stealth for the front, and i would be able to change the PS3 lateron if i became the "lucky" reciever of YLOD.
    Since this aluminium plate is only 1mm, i went with the dremel. Cutted it like butter.
    Next up drilling holes to get the round edges. Had to be very precise.
    Then back to filing to get straight lines and smooth edges.
    The stealth will need to be flat with the front, so it will look like one and same unit.
    Using a router to grind 1mm into the 3mm front was an easy task.
    Next i will need to bend the 1mm aluminium to fit with both the PS3 front and the front plate for the mediacenter.
    I dont have pictures of the way i bended it. Forgot to take the pictures since i was in a hurry.
    Sorry guys.
    The way i did it was by carefully measuring where the bends were supposed to be, then using clamps and aluminium profiles to add preasure where the bend was supposed to be.
    Pretty simple and easy actually.
    Before gluing the PS3stealth plate to the front i need to, you guessed it, glue vener onto the diffrent parts.
    The backside of the front will have vener glued onto it also now.
    The front of the front wont have vener added yet. Still have to have the whole chassis done before thats gonna make sense. Reason for this is that it needs to look like one unit. If i did it now, it wouldnt.
    Having had the vener added, using chissels again to remove the vener from the holes in the front.
    Next step was to glue vener to the edges.
    Again using chissels to remove all leftover vener.
    Keep in mind that this havent been fitted perfectly yet. I wont be able to do that till i have most of the chassis done.
    Also due to a minor design flaw, ive had to change some of the design for the chassis. So im delayed for a week properly.
    This meens that there will probably be another 14 days till i can continue on the log for the mediacenter itself.
    Hopefully i will recieve my wood next week ( Should have already been here this week ) so i can continue on the cabinets for the mediacenter.
    Anyhow,
    I shall return :)
  6. stonedsurd
    11 Mar 2009
    :jawdrop:
    the PS3 stealth is awesome.
  7. M.Ø.J
    19 Dec 2009
    Thanks, glad you like it also :)
    I hope its gonna look even more awesome, closing the last two gaps with acrylic and a white dimmed LED in it, to mix with the dimmed white light the PS3 has when its on.
    The testsetup:
    No LED in the acrylic yet on this picture thou.
  8. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    For one I agree, this is coming along real nice. I can't tell what the finished product will look like either... but I think that's exciting. The headphones look great too btw. Ash is one of those woods that makes me think of a sound-room and HiFi audio, so to me it seems like a perfect choice of lumber. Great job so far. :thumb:
  9. Azayles
    Azayles Minimodder
    6 Jan 2008
    Those slots are filed so perfectly they look almost laser cut :p Good job!
  10. M.Ø.J
    19 Dec 2009
    Thanks a lot. Love it when people have actually spend some time on reading the log. :)
    Are you suggesting that i keep on keeping "the final result" somewhat blurred ?
    I do like my sennheisers a lot. They will look deadawesome with the build.
    Hey mate !!
    Thought you had given up on me. You used to write in my log all the time :D
    Thanks, that observation meens the world to me. :rock:
    Heres a teaser for you guys:
    Thought i was gonna leave it looking like this?
    No,
    no,
    no,
    no,
    Work in progress:
    Just because its traditionally Danish design, im still gonna reach for a more modern look to it.
    Melting danish design with state of the art casemodding is for sure one of my goals here.
    Hope you guys enjoy.
  11. Azayles
    Azayles Minimodder
    6 Jan 2008
    Course I've not given up! Seen some great work happening here and I'm itching to see more! :D
    I been working on a special electronics project so I not been forumming as much, but I'm still around ;)
    Loving the Blueray and PS3 logos, very well done! They look amazing :D
  12. stonedsurd
    11 Mar 2009
    Nice work with the covers. Little touches like that go a long way :)
  13. DeadP1xels
    30 Nov 2009
    This is going to look very stylish when its done :thumb:
    :rock:
  14. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    awsome woodwork dude! really impressive. møj møj møj imponerende:D
  15. M.Ø.J
    19 Dec 2009
    Sweet!
    Im itching also to get further with the progress. Ones timeplanning just never adds up.
    Rather doing a projet that i will love looking at than having this shitty furnituree on my wall that ive done in record time.
    You of all know what i mean :D
    Tell more bout electronic shhhhh. project.
    Me curious!
    Thanks. I did like em also.
    Then when i saw the pictures i realised that the blueray logo had some problems with the corona.
    Also the bend is a bit off. Imgonna redo this part of the build.
    The PS3 im ok with, the bend is very perfect at least. :)
    Thanks, i sure hope so.
    It does look promising at the momoent. But still so much hardware and wires to be positioned in this tiny universe of the ash stealth mediacenter.
    Thanks a lot. Souns like you konw what to expect from this ?
    Hehe, endnu en Dansker !!
    Hvor blev de andre af??
    Gonna tell you a story about "møj imponerende" one of these days that is related to what im doing right here. :)
  16. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    de er i bilka:p men tjek din pm, og tjek den side ud :D
    looking foreward to seing more work:p
  17. Azayles
    Azayles Minimodder
    6 Jan 2008
    Thought you might be! ;)
    I'm building a clock that's gonna comprise many LEDs in concentric rings that'll form the hands of the clock. I'm using a special microcontroller programmed in BASIC as well as a RTC chip and battery backup. I might even be able to squeeze in a GPS module to get accurate time from ;)
  18. M.Ø.J
    19 Dec 2009
    This is really not on purpose. Its due to the fact that i havent had the materials to do the setup to show what the whole concept is gonna look like.
    However after having previewed the logs before posting, i at some points had a smile on my face thinking its kinda cool this way.
    Now my question is, should i keep on posting logs keeping the final result kinda blurred.
    Or would you like a final setup when i get to that point of the project ?
    Edit: Poll added.
  19. Azayles
    Azayles Minimodder
    6 Jan 2008
    I think keep going as you are :) I like the intrigue of not knowing exactly how the final result will look, and seeing it grow with each new idea and new update. Keeps us coming back for more! :D
  20. M.Ø.J
    19 Dec 2009
    Omg, that sound complicated. Can imagine that takes up a lot of time.
    Hoping to se pictures of it when your done. :thumb:
    Er der tilbud paa cola ? :hehe:
