asp:linkbutton
Discussion in 'Software' started by stevejhon, 7 Oct 2008.
  1. stevejhon
    stevejhon What's a Dremel?
    7 Oct 2008
    Hello I had problem
    I want to delete row from my datatable through asp:linkbutton. How can I do this. I had the following code, but it adds another row to the table
    protected void delCart(object s, DataTableNewRowEventArgs e)
    dt = (DataTable)Session["Cart"];
    dt.Rows[e.Item.ItemIndex].Delete();
    //dt.Rows(e.Item.ItemIndex).Delete();
    int CartItem = (int)Session["cartItem"];
    CartItem = CartItem - 1;
    Session["cartItem"] = CartItem;
    Session["Cart"] = dt;
    DataList1.DataSource = dt;
    DataList1.DataBind();
    updateCart();
    Response.Redirect("ShoppingCart.aspx");
    The updateCart() just updates the cart values.
  2. shazzmerc
    shazzmerc What's a Dremel?
    13 Oct 2008
    Hi Steve,
    Try This one I hope it will be suitable for your requirement.
    dt.AcceptChanges();
    after
    Regards;
    shazz
    .Net Consultant
    Phone: (212) 736-3333
