Development ASP Question - Classes & Record Sets
Discussion in 'Software' started by LaughingJon, 10 Feb 2004.
  1. LaughingJon
    LaughingJon What's a Dremel?
    12 Feb 2003
    Hey all,
    i am desperately trying to create a nice well structured site using plain old ASP but stuggling with 1 section.
    I have a class say for example Person, this deals with all person related items like name age etc etc. When i want to add a person to the databse, i create a new object Person and add into that the details, then call a check within that object to check it over, if ok i call another method to write it to the DB.
    That works great.
    Now when i want to come to create a list of persons i have tried a similar method using the record set. However, with the record set inside this Person class i cant reference it at all, i just get error messages like.
    Code:
    Object doesn't support this property or method: 'RecordCount'
    or other such "no what do you think you are doing" kinda messages.
    It works fine if i create the record set inside the page in question, but if it is possible i would like to keep everything person related in person.
    Anyone got any ideas?
    :sigh:
    Cheers
    Jon
  2. Hepath
    Hepath Minimodder
    20 Oct 2003
    Ok
    I knocked up a quick asp class to test this as there should be nothing intrinsically wrong with what you are doing. THese are the possibilities that happened to me as I took off my .NET hat and tried to remember ASP!! :hehe:
    • Ninety-nine times out of One hundred its because the call for the assignment has not been "set". Are you calling a function to get the records set and forgetting to "set" the return value? viz:
      Dim objDataSet
      set
      objDataSet = myPersonCollection.Item[3].GetDataset()
    • It might also be due to the class scope - did you declare the dataset as "Private"? If so - you'll need to expose the properties of the record set you want to see in your containing class.
    BTW: In ASP I would certainly not advise having a collection of Datasets unless their disconnected!!
    let me know if I missed anything or if that helped
    Stu
  3. LaughingJon
    12 Feb 2003
    Hi there,
    Cheers for your reply, turns out i think you were right..
    I was trying to get the record set returned to me from a public method ala.
    Code:
    Public Property Get oRS
      oRS = s_oRS
    End Property
    where s_oRS was private.. The code.
    Code:
    dim localoRS
    set localoRS = tmpStaff.oRS
    Didnt work..
    However, by setting s_oRS to public i can just use
    Code:
    dim localoRS
    set localoRS = tmpStaff.s_oRS
    and it works :clap:
    I dont know if what i am doing is the best way from a coding point of view, but it seemed logical at quarter to 10 last night :D
    Cheers bud
    Jon
  4. Hepath
    Hepath Minimodder
    20 Oct 2003
    That's the problem then:
    oRS = s_oRS
    End Property
    should be
    set oRS = s_oRS
    End Property
    All variables in ASP are of type VARIANT, objects therefore have to be assigned using the SET operator.
    Making the recordset public is a very ugly way of doing what you want.
  5. LaughingJon
    12 Feb 2003
    arrrrrrr cool cheers for that, will try that way instead then :D
    Laters
    Jon
