Development ASP/SQL/ADO help...
Discussion in 'Software' started by rupbert, 9 Sep 2003.
  1. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    Hey guys the basic premise is thus: I have an admin section for a Library Board's contacts, and one of the final pages I am creating is a 'deleteSection'.
    The admin can search for the desired section, and once found they can click on it and pass the unique sectionID through the url. On the final page I have currently been able to retrieve the sectionID from the url, and display a list of contact's that have been assigned the sectionID that has been passed.
    I want to create a SQL statement that checks the recordset that holds the above contacts, and something like
    IF rsSection.recordcount > 0 THEN
    "You cannot delete this section, as users have been assigned etc..."
    ELSE
    "DELETE from tblsection WHERE sectionID LIKE 'varSectionID'
    END IF
    I have not done manual coding for a while now, and I am not sure of the order the code should be placed, and some of the syntax seems alien....
    Here is what I currently have, a mixture of manual and Dreamweaver code:
    'Retrieve the sectionID from the URL and place it in a variable
    Dim sectionID
    sectionID = Request.Querystring("sectionID")
    Dim rsSection
    'Retrieve the list of contacts, if they have been assigned the section
    Set rsSection = Server.CreateObject("ADODB.Recordset")
    rsSection.ActiveConnection = MM_contactsDSN_STRING
    rsSection.Source = "SELECT contactName FROM tblcontacts WHERE sectionID LIKE '" & sectionID & "'"
    rsSection.CursorType = 0
    rsSection.CursorLocation = 2
    rsSection.LockType = 1
    rsSection.Open()%>
    'Check if the number of records is more than 0, if so alert the admin that the section cannot be deleted; if 0 then delete
    ELSE
    END IF
  2. LaughingJon
    LaughingJon What's a Dremel?
    12 Feb 2003
    doesnt it work? Cos that looks like it should work.. As long as you include the <% around the if else endif bits?
    eg this should work.
    Code:
      IF rsSection.recordcount > 0 THEN %>
      ELSE
        set oCmd = Server.CreateObject("ADODB.Command")
        oCmd.ActiveConnection = MM_contactsDSN_STRING
        oCmd.CommandType = 1
        delSQL = "DELETE from tblsection WHERE sectionID LIKE 'varSectionID'
        oCmd.CommandText = delSQL
        oCmd.Execute
    END IF
  3. rupbert
    28 Jul 2002
    Thanks for the reply LaughingJon, I think there is a problem with the recordcount as it still deletes the section even with your cmd...
    I get no errors, it just deletes it!?!
    Here is the current code now:
    Dim sectionID, rsSection, oCmd, delSQL
    rsSection.Open()
    <%Response.Write("You cannot delete this section, as users have been assigned etc...")
    ELSE
    delSQL = "DELETE from tblsection_copy WHERE sectionID LIKE '" & sectionID & "'"
    oCmd.Execute
    END IF
  4. LaughingJon
    12 Feb 2003
    hummmm confusing.. you could try...
    Code:
    if(NOT rsSection.EOF)THEN
    ELSE
    oCmd.Execute
    END IF
  5. rupbert
    28 Jul 2002
    Many thanks mate, I always thought there was a problem with the recordcount because it always returned -1 (a problem with the locktype?)...
    Its working great now, however it checks for deletion onload, I would prefer to have a 'delete' button which then ran your 0Cmd...
    Easy enough?
    I assume its something like Type = Submit onclick = "oCmd"?
  6. LaughingJon
    12 Feb 2003
    hey there
    yeah all you need to do is create a form
    a very simple eg could be..
    Code:
    <% if(Request.Form("subbed")) then
      rsSection.Open()
      ELSE
      oCmd.Execute
      END IF
    else %>
      <form method="post" name="aform" action="your.asp">
      <input type="hidden" name="subbed" value="true">
      <input type="submit" value="Del This">
      </form>
    <% endif %>
    Laters
    Jon
  7. rupbert
    28 Jul 2002
    Many thanks mate, much appreciated :)
  8. LaughingJon
    12 Feb 2003
    i take it by some fluke that code worked of sorts then LOL :)
    NPs bud
    Laters
    Jon
  9. rupbert
    28 Jul 2002
    Hey mate just wondering, as I sit here tweaking the finished pages, I was thinking it might be a good idea to apply a similar IF condition to the Add new Section/Department pages...
    Obviously it would be careless to allow the admin the add a new Section that already exists!
    Just wondering whats the easiest way to go about checking if the sectionID passed through the URL already exists in tblsection_copy?
    IF rsSection.Fields.Item("sectionID) == sectionID THEN
    Response.Write("This Section already exists etc...")
    ELSE
    delSQL = "INSERT INTO tblsection_copy ([section]) VALUES ("section")"
    oCmd.Execute
    END IF
    The SQL syntax is wrong yes?
  10. LaughingJon
    12 Feb 2003
    is this what you mean?
    Code:
    //grab sectionID from URL
    //need to check that there is no section with this ID already created.  thus.
      rsSection.Source = "SELECT * FROM tblsection_copy WHERE sectionID LIKE '" & sectionID & "'"
      rsSection.Open()
    IF not(rsSection.EOF) then
    //section already exists as recordset isnt null
    ELSE
    delSQL = "INSERT INTO tblsection_copy VALUES (" & section & ")"
    oCmd.Execute
    END IF
    Cheers
    Jon
  11. rupbert
    28 Jul 2002
    Yeah cheers mate, knew there was a simpler way to check if the section already existed, thanks :)
    Steve
  12. LaughingJon
    12 Feb 2003
    cool... nps matey :D
  13. rupbert
    28 Jul 2002
    me again :)
    I have this code for the Add New Section page, its working fine. I have three if statements, the first checks that the inputbox is not empty; the second checks if the section already exists and the third runs the SQL statement if no section already exists...
    However, when I go to Add a new section having left the inpubox blank, it returns both the repsonse.write for the first IF statement ("Please enter a Section") and ALSO the response.write for the second IF statement ("The Section you tried to add already exists...")
    Obviously I only want each relevant response.write to display, is there a way round this?
    In Short, if the admin trys to add a blank section, I want to display "Please enter a section"; but I don't want to check if the section exists
    %IF varSection = "" THEN
    Response.Write("Please enter a Section")
    END IF
    IF NOT (rsSection.EOF) THEN
    Response.Write("<font color=##990000>The Section </font><font color=#666666>'" & varSection & "'</font><font color=#990000> you tried to add, already exists...</font>")Response.Write("<br><br>You can try to add another Section, or click <a href=http://belbweb1/_demo/admin_contacts/contactsDatabaseAdmin.asp>here</a> to go back to the main admin page")
    END IF
    IF (rsSection.EOF) THEN
    Response.Write("<font color=##990000>You have successfully added the new Section </font>'<font color=#666666>" & varSection & "</font>'")
    Response.Write("<br><br>Click <a href=http://belbweb1/_demo/admin_contacts/contactsDatabaseAdmin.asp>here</a> to go back to the admin page...")
    delSQL = "INSERT INTO tblsection_copy ([section]) VALUES ('" & varSection & "')"
    oCmd.Execute
    END IF
  14. LaughingJon
    12 Feb 2003
    :D
    well you could either use..
    Code:
    response.end
    to terminate the processing of the page..
    or use:
    Code:
    if  (expression)  then
    elseif(expression2) then
    elseif(expression3) then
    end if
    Either would work..
    Cheers
    Jon
  15. rupbert
    28 Jul 2002
    Scratch that, got it working :)
    Changed this:
    To this:
    IF (rsSection.EOF) AND varSection <> "" THEN
  16. LaughingJon
    12 Feb 2003
    hehehe.. cool :)
  17. rupbert
    28 Jul 2002
    Always used Dreamweaver to do most of the work, you learn a lot more when you are forced to think it through...
    I learned the basic of ASP/SQL around eight months ago, and this is the first time I have had to apply it :)
    Need some books me thinks, got any recommendations?
  18. LaughingJon
    12 Feb 2003
    hummmmm.. books.. unfortunately i havent really used books for ASP or SQL... i mainly use online sites for these.
    http://www.devguru.com
    is good for ASP/VBScript
    Then for SQL i have sql2000 installed and i use the "books online" help which comes with that as it includes examples and searching which helps out lots tbh.
    I am very much self taught both sql and asp as when i started my job i didnt have much choice but to learn.. They tried to make me use dreamweaver etc, but tbh i really dont like those gui interfaces, i would prefer to use editplus2 :D
    But i agree, you need to get down and dirty with the code to really get a better understanding for it. :D
    Laters
    Jon
  19. rupbert
    28 Jul 2002
    Okay mate, I am trying to manually code Dreamweavers bloated version of the Edit Contact page...
    Here is what I have:
    Dim varContactID, contactName, designation, departmentID, sectionID, telephone, email, groups, surname, forename, oCmd, varSql
    varContactID = Request.QueryString("contactID") 'Passed through URL
    contactName = Request.QueryString("contactName")
    designation = Request.QueryString("designation")
    departmentID = Request.QueryString("department")
    sectionID = Request.QueryString("section")
    telephone = Request.QueryString("telephone")
    email = Request.QueryString("email")
    groups = Request.QueryString("group")
    surname = Request.QueryString("surname")
    forename = Request.QueryString("forename")
    Then I have this after numerous standard recordsets:
    <%Set oCmd = Server.CreateObject("ADODB.Command")
    varSql = "UPDATE tblcontacts SET contactName = '" & contactName & "', forename = '" & forename & "', surname = '" & surname & "', departmentID = '" & department & "', sectionID = '" & sectionID & "', designation = '" & designation "', telephone = '" & telephone & "', email = '" & email & "', [group] = '" & groups & "' WHERE contactID = '" & varContactID & "'"
    oCmd.CommandText = varSql
    oCmd.Execute
    I keep getting 'Expected end of statement, line 312'. Line 312 is where varSql resides. Is there anything wrong with the sql statement mate? I am puzzled...
  20. LaughingJon
    12 Feb 2003
    Code:
    should be
    Code:
    department = Request.QueryString("department")
    or change your SQL statement... :)
    Cheers
    Jon
