Small Form Factor ASROCK BC250 thread
Discussion in 'Hardware' started by Sgoaty, 25 Mar 2026.
  1. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I'm about to buy one of these from David I've also seen they're getting to be a bit more readily available from AliExpress ( currently around £110)
    I plan on posting my case/mods and thoughts and thought it would be nice to have a dedicated thread for anyone else who is interested or wants to post stuff about them.
    Arboreal likes this.
  2. Arboreal
    21 Jan 2011
    My spies tell me that avoiding audio over DP sidesteps some problems.
    I look forward to seeing it in progress
  3. David
    7 Apr 2009
    Yeah, audio over USB works fine but audio over DP is just broken.
    You can flash the BIOS for different levels of control over memory allocation.
    Bazzite works great, but SteamOS needs work - I heard it was getting a lot better though.
  4. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
  5. Arboreal
    21 Jan 2011
    That is our old friend 'Andy V-T' late of this forum.
    He's in regular contact with my weekly LAN group and shared the build with us.
    It is neater than some of the home brew solutions I've seen out there
    Ice Tea likes this.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Do the BC-250 have high idle power usage? Sure I saw that on a video about them.
  7. Arboreal
    21 Jan 2011
    Shouldn't do now. They did a while back, but there was a fix that brought it under control.
    GPU governor script to down clock it as it didn't automatically along with undervolting from memory.
    David and Ice Tea like this.
  8. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    If it wasn't for the tinkering and all the cables i would have loved one of these for a daily linux desktop.
  9. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    I've done a little research on PSUs and apparently 300w should be more than enough so I've ordered a metalfish unit. I was quite impressed with the 600w version so hopefully this one is good too.
    Ice Tea and Arboreal like this.
  10. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Trying to decide between a single or dual fan case. Quite like the look of the steam machine single fan units but not sure if I should just make it bigger and cool better.
  11. David
    7 Apr 2009
    If you open up the rest of the fins and mount a pair of fans, that will be the most efficient method.
    If you're thinking about a push-pull setup like this...
    ...save your plastic, it ain't worth it; unless you plan on investing in a pair of really beefy server fans and some ear defenders.
  12. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Ha no that's not my intention I plan on something prettier and quieter hopefully
  13. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Is it worth a slim fan on the back as well?
  14. David
    7 Apr 2009
    This guy has put a lot into the BC-250 - well worth a sub
  15. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Subbed, thanks.
    Did you update the bios or anything when you had it? I think it'd arrived just haven't opened the box yet to delay the " what shite are you buying now" conversation with my wife for a little bit longer :p:
  16. David
    7 Apr 2009
    I played around with a few updates - I think I left one on that allows you to change the RAM allocation. I think if you set the GPU to 512MB it will pull what it needs dynamically, iirc.
  17. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
  18. Sgoaty
    Sgoaty Multimodder
    4 Feb 2005
    Straightened out the rest of the fins and installed a couple of fans. I've updated the bios probably didn't need to but following the process.
    I've also installed Bazzite and tried to get my head around increasing CPU and GPU performance. I've managed to get the GPU drawing up to 180w but can't figure out how to install CPU-X Linux causes me a lot of confusion!
    Case is just about ready too but awaiting power switch and PSU. I wish I'd went higher than 300W now that I see how much I've managed to get it pulling (280w from wall so far)
    Yaka, Ice Tea, David and 1 other person like this.
  19. meandmymouth
    15 Sep 2009
    If I wasn't trying to be sensible I'd be buying one of these and having a play around.
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Before you fire up a 3D printer, be aware that he updated the design yesterday (30/03/2026)
