Hardware ASRock P67 Extreme4 Review
Discussion in 'Article Discussion' started by arcticstoat, 5 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    Am I the only one thinking Cooler Master may pay them a visit about the chipset heatsink?
  3. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Exactly what I thought too.
  4. kenco_uk
    28 Nov 2003
    Can't wait for the roundup.
    Will there be any Z68 reviews on the 8th? :)
  5. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    I don't think you are.
  6. borandi
    borandi What's a Dremel?
    27 Jan 2010
    That SATA 3Gb/s read speed seems low. Was the OS installed in IDE or AHCI mode? There's at least a 30 Mbps read difference in that setting. Annoyingly win7 doesn't install the AHCI driver if you install the OS in IDE mode, so have to reinstall everything.
  7. enikmaster
    enikmaster What's a Dremel?
    10 Jul 2009
    Nice board. I like the layout. The performance is not very bad.
  8. kenco_uk
    28 Nov 2003
    No you don't!
  9. randis1981
    randis1981 What's a Dremel?
    4 Nov 2010
    revision GIGABYTE GA-P67A-UD4-B3 ATX Intel
  10. randis1981
    4 Nov 2010
    revision GIGABYTE GA-P67X-UD3-B3
Tags: Add Tags
