Steam Assassins Creed 3 - 50 Copies to Giveaway!!
Discussion in 'Gaming' started by TheGreatSatan, 6 Dec 2012.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Awesome thanks Dom I appreciate it.
    It doesnt help that its Windows 8 and its on my TV!
  2. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    Ok go check your emails should be one from Ubi with download links and a serial key. I know that I have one.
    So you should too, pfft TV. And Win7 all the way :lol:
  3. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Again - Thank you so much for this! The second key worked flawlessly. :thumb:
  4. bdigital
    10 Aug 2010
    Unfortunatly I dont have an email from ubi :waah:
    I doubled checked the desktop and there was a folder called 'download'. In it, was a whole bunch of AC3 rar files but no setup. I tried extracting them but quite a few failed so no luck there.
    It would appear the download has bricked itself and the key / game is gone forever!
  5. MrDomRocks
    5 Sep 2011
    Damn contact Ubi support my friend they should have records of the transaction. Without the email you can't do anything as it has your key inside too.
    Checked spam folder?
  6. GregTheRotter
    GregTheRotter New Member
    9 Aug 2008
    I don't suppose there are any copies left since I don't think I entered :(
  7. Guest-23315
    Guest-23315 Guest
    I downloaded all the files onto my dump drive, but when I run the installed/unzip it it tries to dump it all on my SSD which has about 2Gb's of space on it, and give me no way of changing where I want to extract the thing to... So gets ~15% of the way through and has a headache.
    **confuddled or stupid**
  8. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Not sure
    Maybe you should clone it all to something bigger. Pay attention to upcoming contests!!
    finboz likes this.
  9. Whindog
    Whindog New Member
    16 Sep 2010
    One day....ill be one of the lucky ones......One day :)
    Love your work TGS
  10. TheGreatSatan
    5 Aug 2005
    Check your PM
  11. Ripitup121
    Ripitup121 MMMMMMm watercooling....
    18 Aug 2010
    I had the same issue Mankz,
    Solution:
    Use winzip/winrar to extract the first downloaded file to folder on HDD. it will automatically do all 23 parts of the download as part of it and then run the setup.exe and you can select where to install then as usual in the menues :)
    hope it works!
    Rip
