Other Assessing Price/Performance Efficiently?
Discussion in 'Hardware' started by TheMusician, 13 Mar 2010.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Once upon a time, TomsHardware had Price/Performance ratio charts which were of great value to me, because they were excellent for comparison. They have since disappeared.
    What do YOU guys use to determine such information these days?
  2. TheMusician
    13 Jul 2009
    Shameless bump.
    :blush:
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Basically, I just read a lot of reviews. Price/performance ratio is relative to each individual person anyways.
  4. TheMusician
    13 Jul 2009
    Hmm.
    I thought TH did it by dividing the 3DMark score by price
  5. Ph4ZeD
    22 Jul 2009
    Thats a pretty crude way of obtaining what is good value for money. There are a lot of different features and things which matter to the individual buyer.
  6. wyx087
    15 Aug 2007
    read Bit-tech reviews, if it's featured in their monthly buy guide and/or been given a recommended icon.
  7. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Seconded, bit-tech is very conscientious of the wallet/performance demands. And they really give unbiased information. Bit wont steer you wrong!
    (un-official pumper of bit-tech) :rock: :D
  8. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    Is this for GPUs? Hexus does a comparison and with them including the prices you can recalculate. Techpowerup does a nother one but without the prices included its nigh on impossible to recaculate.
  9. Ph4ZeD
    22 Jul 2009
    Theres really no need to look at charts and ratios, just use your brain. Decide your budget, and check the reviews of cards around that budget in the games that your currently playing. Its really that simple. Price/performance charts can be a tad irrelevant because they are only done in certain games that you do not play and telling someone with a £300 budget that a 8800GT is best value for money is pretty pointless.
  10. Domestic_ginger
    16 Mar 2010
    Agreed however the price performance ratio is literally price to performance; not most expensive card that fits into a budget. You should be able to assess if you are spending 50% more on a card which only contributes 20% extra performance.
  11. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Expanding on this, it's a good idea to determine a price range and record what cards fall into it. I like to check reviews to gather as many benchmarks from games/3Dmark/furmark etc and see the average percentage of performance increase over your current card (if you can get applicable benches for it) or from one of the cards in your selection (usually the cheapest). Once you have percentages for price difference and performance difference you subtract the price % from the performance % and the highest value wins.
    Example:
    Card A scores 100, Card B scores 120, Card C scores 130. 20% for Card B, 30% for Card C.
    Card A costs 100, Card B costs 110, Card C costs 140. 10% for Card B, 40% for Card C.
    Card A total = 0. Card B total = (20%-10%) = 10. Card C total = (30%-40%) = -10.
    Card B has the highest number! For the 100 to 140 cost range it is the best.
