ASUS A7N8X-E-Deluxe booting problem
Discussion in 'Hardware' started by [S]huttle, 9 Jun 2004.
  1. [S]huttle
    [S]huttle What's a Dremel?
    15 Sep 2002
    I'm having a problem with this motherboard. I keep getting this error when I try to boot up the system I double checked all my connections, I even hooked up another hd with a fresh install of WinXP. Here's the specs. Any help would be appriciated Picture of the problem Picture of the problem
    Barton 2600+
    SilverStone Strider Series 400 Watts PSU with PFC
    GeIL Ultra Platinum PC3200 400MHz Dual Channel DDR Kit
    Radeon 9000
    Polarflo water cooling kit
    PIONEER DVD-120S 16X-DVD
    Microtek 17" LCD
  2. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    try some different memory - I've had problems with Geil in Nforce2 motherboards. also try a bios factory reset incase a cmos value corrupt. Aslo check CPU temps and make sure you have a fan sensor connected to the CPUFAN header.
  3. jberry3
    jberry3 What's a Dremel?
    21 Dec 2003
    Had the same problem on the a7n8x deluxe when installing xp turned out to be faulty memory.
