News Asus announces GTX 980 Ti 20th Anniversary card
Discussion in 'Article Discussion' started by Gareth Halfacree, 26 Nov 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. raxonb
    raxonb Minimodder
    5 May 2009
    "For extreme overclockers the board also includes Memory Defroster, which quickly defrosts the VRAM when the board is used under liquid nitrogen or other below-freezing cooling systems"
    Quite possibly the most awesomest thing I've ever heard
  3. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    I thought the DCU III design was out already? Unfortunately the DCU II does not offer VRAM cooling afaik but I think the DCU III does.
    In my case (R9 280) It is able to handle a hefty core OC and the cooler performs very well, but the lack of VRAM cooling on this card supposedly aimed at overclockers is a huge oversight IMO.
    Could be wrong and my DCU II cooler is some cut down piece of garbage they slapped on it and called it DCU II.
    However I do like the color scheme as it would fit perfectly with my current rig (mostly Asus gold + black). I'm looking for a worthy upgrade and honestly even with the issues of the DCU II cooler, I do like it. Not sure I want to pay extra for stuff I will obviously never use like the 'memory defroster'.
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Finally a graphic card from Asus that matches their motherboards' gold colour theme xD.
  5. Ryan@ASUS
    Ryan@ASUS What's a Dremel? Moderator
    23 Oct 2015
    The number after the Direct CU is just indicative of the number of fans used, this uses 2 so is DC2. Newer GPUs will always tend to have the newer variation of the DC cooler but that has no correlation to the number, the number is the number of fans. All Direct CU coolers are validated and tested to provide excellent cooling to the VRAM be that through thermal pads or just direct channeled airflow.
    Oh and pricing is expected to be around £719.99, quantities in production will be very limited!
  6. SinxarKnights
    21 Jan 2007
    Interesting! Yeah wish mine had direct contact with the VRAM. Thanks for clearing that up.
