Hardware Asus Ares II review
Discussion in 'Article Discussion' started by brumgrunt, 12 Feb 2013.
  1. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Obscene....in a good way.
  2. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    OK, OK, you know that I meant three of those things in CrossFire (if it's even possible).
    On second thought, as Shirty said, there should be a server board out there that could fit four of them ... Volunteers, anyone ... :worried:
  3. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Only a single CrossFire bridge on each card, so you couldn't do it even if you did have three. It was pretty awesome doing the 7,680 x 1,440 tests though :D
  5. walle
    walle Minimodder
    5 Jul 2006
    Two cards and you could run your own weather simulations in real-time...assuming the drivers work :D
  6. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Ordered
  7. Jipa
    5 Feb 2004
    Behold! The absurdity arrives.
  8. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    But can it play Crisis 3?
  9. ArcAngeL
    ArcAngeL What's a Dremel?
    14 Nov 2006
    Is it me or does it appear there's e not enough space to run in SLI?
  10. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    Does it come with an "in-case tripod" to support the front right corner of the card? Seeing as how it must weigh as much as a small car. :p
  11. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Too much for something is about to get undated.
Tags: Add Tags
