Asus Commando
Discussion in 'Article Discussion' started by Tim S, 6 Mar 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. NuTech
    NuTech Minimodder
    18 Mar 2002
    Quality review to Bit-tech's high standards as usual. :thumb:
    On a side note, anyone know what ever happened to the Asus Frontlinker? Maybe somebody at HQ can pull some strings and find out?
  3. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    So is the Asus P5B Deluxe the better board in terms of value/features then?
  4. Guest-16
    Guest-16 Guest
    Depends what you're after, Wifi? Solid state caps? LCD screen? Onboard switches? A couple more heatpipes to provide better stability during the summer? Slightly better overclocking potential, 400 or 450? You have to judge if the £20 is worth it considering your needs.
    Nu: I'll put it on my list to ask Asus at CeBit.
  5. Krikkit
    21 Jan 2003
    Awesome review yet again, there's a flurry of mobo's coming atm, it's awesome. :D
    Looks like a good board really, have you any quibbles that didn't make it to review?
  6. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    As always a good review by Bit-tech.
    Seems quite a variable board going by the forums - some people think that it's as simple a case of QC & whether they were made in the new Chinese factory or not.
    Also a lot of reports of them being noisy, Clunk over on Hexus had 3 which I think have all gone back (certainly 2 have).
    Plans for an AB9 QuadGT review?
  7. rupbert
    28 Jul 2002
    @ BUFF
    Noisy when using the optional cooler?
  8. Guest-16
    Guest-16 Guest
    Noisy? As in electrically? Because the thing doesn't have a single fan. I never used the optional cooler, and it survived 24 hours of stress test without it.
    When I see Abit at CeBit I'll ask for one. We gave up on the AB9 Pro since ours died :(
    We had 3 EVGA 680i boards and every one was bad, so sometimes you get good and bad batches of any manufacturer.
  9. BUFF
    25 Mar 2005
  10. rupbert
    28 Jul 2002
    @ BUFF
    That sounds like a group of defective boards, when you said noisy I assumed every board was inherently noisy.
    I've used the Asus P5B-Deluxe without this problem, so I'm guessing it's not a widespread issue?
  11. BUFF
    25 Mar 2005
    well they've been in the US, UK & Europe so it's a big group ...
    HardOCP just posted their review today & they too struggled to get over ~460fsb.
  12. rupbert
    28 Jul 2002
    @ Bindibadgi
    Can you confirm the review board did not have this 'buzzing' issue? It would put me off buying it to be honest.
  13. Guest-16
    Guest-16 Guest
    Well the labs aren't exactly quiet with some seven machines running on and off, but I'm usually pretty susceptible to high pitched whines and this didn't have any that I noticed the entire time.
    I was actually looking at a way to stop the coils whining the other day: apparently if you move them whilst the board is running (with something non metallic) until they seem better, and drop liquid neophrane/silicon on them it kills the noise.
    We've had this board since mid-Jan though, so if recent board batches are iffy either try to wait or buy from somewhere noone else does?
  14. rupbert
    28 Jul 2002
    @ Bindibadgi
    Thanks for the follow up.
    I think I'll probably go for the P5B-Deluxe instead, I would be concerned that I couldn't return the Commando because it 'whines'...
  15. Guest-16
    Guest-16 Guest
    Go for it, you'll save twenty quid in the process and gain onboard WiFi. Asus even do a Vista edition P5B now.
  16. rupbert
    28 Jul 2002
    Vista Edition?
  17. DougEdey
    5 Jul 2005
  18. randosome
    randosome Banned
    17 Sep 2006
    so whats the difference, it supports a TPM module (but you have to buy it separately)
    And it supports readyboost - though i don't understand how that makes any difference to the motherboard at all
    And i guess it has vista drivers
    did i miss anything ?
  19. Kubix
    Kubix What's a Dremel?
    12 Mar 2007
    Had a commando since it came out, not noticed a whine or anything off the board. Running it will an E6700 and it never skips a beat, one of the better boards i have had. the optional cooler i havent used a there is plenty airflow within the case.
  20. rupbert
    28 Jul 2002
    Thanks for that, and welcome to the forums :thumb:
Tags: Add Tags
