Hardware Asus CrossHair II Formula and Hybrid SLI
Discussion in 'Article Discussion' started by Tim S, 15 Aug 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. kenco_uk
    28 Nov 2003
    Is the 'hybrid' 8200 able to be used as a Physx 'card'?
  3. Nuffenburger
    Nuffenburger The Burgerman Can
    18 Sep 2007
  4. naokaji
    naokaji whatever
    8 Dec 2006
    I'd rather see hybrid sli on a no thrills matx board than this feature loaded beast, sure, the mainboard has "everything", but if you are going for an amd cpu it wont be a attempt to build a high end gaming system anyway.
    good job on the review though.
  5. Guest-16
    Guest-16 Guest
    Hmm, nice idea. I'm not sure actually, it eats up a lot of memory bandwidth so it could be too slow.
  6. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    anyone else find it slightly amusing that crosshair motherboards aren't crossfire compatible?
  7. Ninja_182
    Ninja_182 Enginerd!
    2 Apr 2002
    Not as amusing as the little lights everywhere that signify 'normal', 'high' and 'crazy' :)
  8. ComputerKing
    8 Sep 2006
    HOT HOT! Freaking HOT!
    Guys Asus are the sexist thing you can get in this planet.
    Very dam cool . I can't wait for x58 :p
  9. sl1xx
    sl1xx What's a Dremel?
    12 Apr 2006
    ever mobo just looks the dogs gonards nower days dunnit i think its a pritty gd mobo not 2 steep on the £cedits either id still go with a p45 tho for tha price..
  10. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    looks for once like its the same price in the uk as the us
  11. Guest-16
    Guest-16 Guest
    What language is this :confused:
  12. sl1xx
    12 Apr 2006
    scouse...get with the programme lad !
  13. ComputerKing
    8 Sep 2006
    :waah: and I thought my English was bad :duh:
  14. Guest-16
    Guest-16 Guest
    Ah, I can understand Mancunian, but Scouse and Jordie is beyond me :p
  15. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    I had that board for a while, and could run dual monitors with Hybrid SLI :) Was nicer than dual monitors with normal SLI because the change between SLI / Hybrid worked 99% of the time instead of 80% of the time.
    Unfortunately the Phenom CPU (which I got to 2.9Ghz too) is hopelessly slow. It was slower (actual playing wise, not benchies) than my Intel Quad (3.4Ghz - I know not a 'fair' comparison) with a single GPU. Not a little slower either, the difference was staggering since the Intel system was smooth, while the Phenom though it had the FPS, had constant stutters. Mini-stutters very often, and a big stutter/pause every 10 seconds or so. It made games unplayable if you value great accuracy, such as MOH:Airborne when using a rifle. Incidentally I never had a stutter problem when I ran dual P4 Xeons with SLI.
    Can't fault the board though, I thoroughly enjoyed using it and shall remain one of the favourite boards I've ever had. It's not perfect, but it has plenty of character and just keeps on giving. If the AMD Phenom was a great deal faster, there is no question I would be running Phenom with that board.
  16. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Have had the board for a while now with a Phenom II 940 and found it to be simply superb.
    On air I can get the Northbridge up to 2640Mhz with a 264Mhz FSB and 10 mulit The HT link is running at 2112Mhz and is Rock Stable
    Also is 100% stable with a 14x Multi and 3.7Ghz.
    Memory Bandwidth and benchmarks are superb this board really does make sense when paired with a Black Edition 9** series
Tags: Add Tags
