Hardware Asus Crosshair VI Hero Review
Discussion in 'Article Discussion' started by Combatus, 17 Mar 2017.
  1. Combatus
    16 Feb 2009
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Right now this board is too good for the overclocking capabilities of the Ryzen CPU's.
    ...It should come in to its own with the 1st or 2nd refresh of Ryzen's next year I guess.
  3. Cr@1g
    Cr@1g What's a Dremel?
    19 Oct 2011
    OK, what are we comparing this to? Why is there only one benchmark to view per test? Surely you it would have similar spec Intel boards in there for reference?
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Has it actually been established yet if the current Ryzen oc capabilities are limited by the CPU or the horribly immature bios versions plaguing all AM4 boards?
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    This is a motherboard review, so it makes sense to compare like-for-like products, or in other words only varying the component being reviewed. If this is the first Ryzen board to be reviewed then it makes sense that there aren't any other points of comparison yet.
    I mean, you could compare a Ryzen 1800X, 2400MHz RAM and this board against an Intel setup with a 5820K, the same RAM and an X99 board, but what would that tell you about this particular X370 board? Not a lot, as any variation in performance between the two setups could be down to a number of factors.
    Incidentally, the specs on page one state that this is a Z170 chipset :D Might want to fix that :)
  6. Vault-Tec
    30 Aug 2015
    From what I have seen so far I would stick my neck out and say the CPU. They are doing a new revision in 2018, I expect those to be better for overclocking.
    Still, 4ghz isn't a bad start really. Especially when most 1700s seem to be hitting those speeds.
  7. Spigsy
    Spigsy What's a Dremel?
    28 Sep 2009
    How would that help anyone comparing apples to oranges? Obviously BT will flesh out the results as they get more boards to review. How Intel motherboards perform is irrelevant when you're looking at Ryzen, and for the CPU comparisons look elsewhere.
  8. Spigsy
    28 Sep 2009
    Pedantry maybe, but according to Silicon Lottery, only 26% of 1700s are stable at 4ghz, though 77% will hit 3.9GHz.
  9. Vault-Tec
    30 Aug 2015
    I've not seen an awful lot of them in use TBF. The ones I have seen have been good for 4ghz though :)
    I guess once everything settles down (bios, ram support, bugs, crashes etc) we can get a better idea.
  10. Instagib
    Instagib Minimodder
    12 Mar 2010
  11. Combatus
    16 Feb 2009
    This. As always with new launches we don't have any comparison numbers with the first motherboard review. We'll have the next one out asap but it hasn't helped that the whole Ryzen launch hasn't been problem free. Lots and lots of teething problems.
  12. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Oh my goodness look at all those beautiful rear USB ports!
    That's one trend that can take a hike, all the bloody ports are missing nowadays. Would rather not use hubs for mundane things that I want plugged in all the time.
  13. Panos
    Panos Minimodder
    18 Oct 2006
    A small FYI. This board has the tendency to burn X CPUs by overvolting them while at stock speeds. No need to overclock them.
Tags: Add Tags
