Notebooks Asus EeePC & XP 64 bit?
Discussion in 'Hardware' started by Akava, 19 Sep 2008.
  1. Akava
    Akava Lurking...
    28 Jul 2007
    Righty, I'm looking to get an Asus Eee PC, probably the 1000 (Linux).
    The problem I have is that at college all the machines are Windows based, so it would make sense if the Eee I had was Windows too.
    The problem with that is, I don't want the 1000H because a portion of the point for getting an Eee is the SSD, not a big problem I grant you, but non-the-less.
    So the only solution is to install XP Pro myself on the 'nix version, I have a key and the disc's etc, but only for the 64 bit version, so my question is, will the Eee run a 64 bit OS?
  2. Akava
    Akava Lurking...
    28 Jul 2007
    Looks like I may have answered my own question...
    http://ark.intel.com/cpu.aspx?groupID=36331
    So this means that as it doesn't have the 'Intel® 64 Architecture' it can't run any 64 bit OS right?
    EDIT: Just had a thought, would it be possibly to run XP Pro 64 Bit as a virtual machine within Linux? Thus giving me the functionality that I require while also giving me a good size SSD.
  3. Guest-16
    Guest-16 Guest
    Yea it'll run a 64-bit OS. I've installed Vista 64 on an Atom machine before.
  4. Akava
    Akava Lurking...
    28 Jul 2007
    Awesome, I'll just run the Linux version with XP on a partition then, ta very much for the info. :thumb:
  5. CasperHazeo
    CasperHazeo What's a Dremel?
    12 Oct 2010
    The answer above is wrong...
    You can only install a 32 bit version of Windows on the Eeepc. ... Even the n270/280 support 64bit but this is disabled by Intel on purpose ...
    sorry..much luck in the future!:rock:
