Hardware Asus GeForce GTS 450 TOP Overclocking
Discussion in 'Article Discussion' started by CardJoe, 22 Sep 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    how does the 450 compare against the 9800 GTX?
    is there anywhere easy, i can compare the two?
  3. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    And what about the HD5750 and 5770? It would be nice to compare to similar priced hardware...
  4. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    There are HD 5770 numbers in our original review of the reference GTS 450.
  5. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    Gnnrh! Must...sell...2yo...HD4870...and...buy...equally...performing...GTS450...
    ...pfft.
  6. Kamikaze-X
    Kamikaze-X Minimodder
    24 Apr 2009
    it would be so useful for you guys to include some of the previous gen cards results in graphs, like the 4870. comparing cards that you haven't got when considering an upgrade isnt the most useful way of deciding.
  7. memeroot
    memeroot aged and experianced
    31 Oct 2009
    I think the issue with all these cards is they're slower than the (old sooo old) cards that we have at the moment.
    where is the top range? have nvidia still not fixed the 100% gtx480 or got a dual card single slot solution for us?
  8. yakyb
    10 Oct 2006
    that is exactly the poitn i was trying to raise
    i have mentioned it a few times but is fundementally impossible to do on this site. I do prefer this site over any other for its forums and general reviews but if i want to compare products i have to go else where
  9. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    Asus Smart Doctor it self has not changed for the last 5 years
  10. Jim
    Jim Ineptimodder
    2 Sep 2007
    Sure? :)
  11. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    Surely overclocking a card like this is a way to get more performance from a cheaper card - buying a pre-overclocked card for the same price as the next model up can't ever make sense can it?
  12. V3ctor
    10 Dec 2008
    Thanks for the link
  13. douglatins
    douglatins What's a Dremel?
    28 Nov 2009
    So how does a very "QUITE" fan sounds like!
  14. Claave
    Claave You Rebel scum
    29 Nov 2008
    We understand what you're saying, but here's the problem from our point of view. First off, we want to stress the cards on test as much as possible, so most of our standard tests use DX11 which the previous generation doesn't support.
    The killer reason for not including old cards is that if you're looking at graphics card reviews or are looking to upgrade, you already think your current card is too slow. Therefore you want a new one that's fast enough for the screen you have. Our reviews serve this purpose perfectly.
    I really hope that was ironic... :D
  15. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    I think the point being made is that the word should be 'quiet' and not 'quite'. ;)
  16. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
Tags: Add Tags
