Overclocking Asus GTX560ti DirectCUII overclocking advice?
Discussion in 'Hardware' started by Darkwisdom, 29 Mar 2012.
  1. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    I finally worked up the nerve to overclock my card. I got it to about 890 core clock and 2100 memory clock to be stable, worked it on the extreme test on kombustor. I only reached 63C max on load.
    Now the question is... should i up the voltage a notch? I haven't unlocked the voltages yet, so it's still on stock voltages.
  2. Guest-16
    Guest-16 Guest
    Are you using GPU Tweak?
  3. Darkwisdom
    27 Aug 2011
    Yeah. Gpu tweak combined with msi's kombustor. I then use unigene heaven to bench and to do a final stability.
  4. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    MSI Kombuster is not much of a test to be truthful. Unigine Heaven and in game would be the real test to prove the reliability of an overclock.
  5. Guest-16
    Guest-16 Guest
    Yea push the voltages that's what they are there for. ;) You'll hit a point where it suddenly goes v.hot and that's when you drop off.
  6. Blogins
    3 Aug 2010
    I found the GPU tends to become unstable before the temperatures even become an issue where my GTX 460 SLI are concerned. Game at 890MHz on the core which on air and in SLI is pretty damn good for GTX 460. Beauty of these older Fermi cards is the ability to customise the BIOS fairly easily. I modified mine so the voltage is not limited to stock settings! :D
