ASUS M5A99X EVO
Discussion in 'ASUS' started by AoE, 7 Dec 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Is this board any good or rather designed worth overclocking in mind? I plan on OC'ing my amd fx 4100 bulldozer from 3.6ghz to 4.5ghz, which from the reviews I have read shouldnt be too diffcult
  2. Guest-16
    Guest-16 Guest
  3. AoE
    4 Oct 2011
  4. Guest-16
    Guest-16 Guest
    BIOS updates are free.
  5. AoE
    4 Oct 2011
    thanks were do you get them? sorry for the nooby question.
  6. AoE
    4 Oct 2011
    do I need to download all the new downloads from this section or is it just the most recent one?
  7. Guest-16
    Guest-16 Guest
    You just need the most recent BIOS. You don't need all the new downloads, although if there are some dated within the last month or two it would be better to use that than the one of the CD. It doesn't really matter though.
    Put the BIOS on a FAT32 formatted USB stick then plug it in before you boot. Go into the BIOS and use the EZ Flash to update it.
  8. AoE
    4 Oct 2011
    Thanks works a charm, I have one question though, it seems sometimes when I boot my computer up that the computer doesnt go to desktop and stops at the American trends Bios screen thing, instructing me to save new settings in BIOS? whats the reasoning behind this?
  9. Guest-16
    Guest-16 Guest
    Go in once, then press F10 and exit. All saved, should work.
