Hardware Asus Maximus II Gene Review
Discussion in 'Article Discussion' started by Tim S, 20 Jul 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    That's quite an attractive little board, that.
    It's even easy on the eyes.
  3. KRyptonKR
    KRyptonKR What's a Dremel?
    20 Dec 2008
    Asus Rampage II GENE vs. EVGA X58 SLI Micro review. Please.
  4. Henry CPU Freeze
    Henry CPU Freeze What's a Dremel?
    19 May 2009
    Problem is that EVGA suck balls tbh
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    How could you not have benched this against the direct main competition:
    DFI LanParty JR P45 T2RS
    It's almost identical in layout, but over a year earlier to market and a good bit cheaper.
    I'm running one with a QX9770, and it's a real screamer.:rock:
  6. Guest-16
    Guest-16 Guest
    I would say the Rampage II Gene review is in progress today, however it's just decided to BIOS corrupt when I tried to overclock. Appears to be dead now...
  7. Guest-16
    Guest-16 Guest
    We had one, but I don't know where it's gone. The box is here....
  8. Xtrafresh
    27 Dec 2007
    Riiiight... well you could at least compare packaging then! :duh:
  9. scrimple3D
    scrimple3D What's a Dremel?
    29 Apr 2009
    Isn't the DFI JR P45 T2RS board limited to 8 lanes per PCIx16 slot?.... for starters. I've used one too, overclocked nicely etc, but didn't notice the 8 lanes restriction (even with only 1 video card fitted) until some time later.
  10. Xtrafresh
    27 Dec 2007
    So in answer to your question, every P45 board has that restriction. But TBH, the bandwidth on PCIe has more then enough headroom to make do with 8 lanes.
  11. Guest-16
    Guest-16 Guest
    No the DFI is hard locked to x8 x8 making it cheaper, but other boards give a choice of x16 for a single card, or two x8s.
    There's no performance difference though - you'd be very hard pushed to notice.
  12. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    so it blew up after the review? that's not good- maybe like the issue with the old nvidia 680 when if you started her up with the cmos jumper in the clear position- it had a chance to literally catch on fire.. I mean flames shooting out kind of fire down on the bottom end of the board
    it happened to a couple of peeps I remember.. they had the exact same fire start buring on the board in the same spot- and their jumpers were both on clear =p 1 is maybe a fluke.. but 2 :sigh:
  13. Xtrafresh
    27 Dec 2007
    Oh rite, i stand corrected :D
    Anyway, at least i can still find mine :search:
  14. Guest-16
    Guest-16 Guest
    No the Max II Gene is fine, it's just the Rampage II Gene that has died mid-review. We're waiting on another board to try and do the same...
  15. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    The last of the four-fives I guess...
  16. denis6902
    denis6902 deathbox
    28 Sep 2008
    what would be the best investment in planning a P45 workstation nowadays? Asus P5Q-E since it supports 16GB of memory?
    Would it be too hot? support for nvidia cards? waterblock availability?
    Anyone good with that? Or would it be better in a lower i7 configuration? Please bear in mind the prices couse that is very important, money is not falling off the trees here :(
  17. Xtrafresh
    27 Dec 2007
    wrong thread? :sigh:
  18. denis6902
    denis6902 deathbox
    28 Sep 2008
    was just wondering if u would get a quick advice that's all, specially after reading the gene review. Perhaps someone out there is up to date with it and could give a smart advice :D
  19. Xtrafresh
    27 Dec 2007
    well, you are informing about 4 specific queries, plus a price-conscious comparison with core i7. That's hardly quick advice. :p
    Also, since you don't explain the specific use case and budget, all anyone here could say is: P45 is a decent platform, especially for the price, and virtually any motherboard will do. I really advise you to start a thread with some details though ;)
  20. denis6902
    denis6902 deathbox
    28 Sep 2008
    lol, i mentioned that mainly i use it as workstation, at the moment i got a striker 2 extreme which is absolutely annoying with voltages and so on, and i havent got time for that crap, thas why im thinking in moving away to something more stable but as fast and powerfull. Cause mainly i use it for solidworks, sketchup and other editing tools, not gaming at all, but i love to me able to fold nvidia as fast as it can go :D
Tags: Add Tags
