Motherboards Asus Maximus IV Extreme (P67) or Asus P8Z68 V Pro/Gen3
Discussion in 'Hardware' started by kissinger, 13 Dec 2011.
  1. kissinger
    kissinger Minimodder
    6 Dec 2011
    So I'm in the market for a mobo and I've narrowed it down to these two. Basically it's a choice between a top of the range P67 board or an upper-mid-range Z68 board. The price difference is around £50, with the ROG board (obviously) being the more expensive.
    So which one do you guys think I should go for. I don't really care about Smart Response because I'll just install my OS on a separate SSD, but the Z68 might still be worth it. Advice?
  2. murraynt
    murraynt Modder
    6 Jun 2009
    If it's for overcloking go with the P67.
    Something less extravagant will probably be sufficient.
  3. Guest-16
    Guest-16 Guest
    It comes down to: do you really need Gen3 PCIe upgrade in the future? Or do you prefer the ROG style/features in your system?
