Hardware Asus Maximus VIII Formula Review
Discussion in 'Article Discussion' started by Combatus, 12 Jan 2016.
  1. Combatus
    16 Feb 2009
  2. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Crazy fast, crazy features, crazy price = Near perfection.
  3. Spigsy
    Spigsy What's a Dremel?
    28 Sep 2009
    I'm waiting for the white version. ;-)
  4. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
  5. Combatus
    16 Feb 2009
  6. The_Crapman
    5 Dec 2011
    Ouch! I sure didn't miss that price. Sticks out like a like where's wally at a fugees gig. It sure is pretty though. Shame they didn't also light up the Maximus viii logo above the rear io.
  7. Ryan5508
    Ryan5508 What's a Dremel?
    7 Dec 2007
    How are the led connected on the mobo? I just received mine and the formula logo is different then the rest of the board expect for when its yellow/red. Just wondering if this is something I can fix on my own or not.
  8. TheMadDutchDude
    23 Aug 2013
    I'd just RMA it if it means that much to you. They're controlled via software, so perhaps there's a slight fault somewhere.
  9. Combatus
    16 Feb 2009
    If it's not showing up in some colours but it is in others then there's not a lot you can do other than RMA - sounds like part of the LED is defective - although you say different, so do you mean it's illuminated but in a different colour? All the LEDs are connected to headers on the motherboard under the shroud.
  10. Ryan5508
    7 Dec 2007
    In the aura software its just one color wheel for the entire board.
    So when I change it to say purple everything is purple except for the formula logo is red.
    When I do blue the logo is green
    When I do white the logo is yellow
    Red and yellow work as intended
    I really don't want to rma it after installing all my water cooling. especially after I slightly scratched the rog armor around the ek blocks. I did a closer inspection and the leds are directly on the board. I was hoping for a plug that went into the armor itself.
    On that note-You do need to be careful with your fitting choice since the ek block is not level with the rog armor. there is a slight indentation that will not allow a perfect seal with 90 deg rotary fitting.
  11. Ryan5508
    7 Dec 2007
  12. hero1
    hero1 Minimodder
    18 Oct 2013
    Lovely board. I currently have Gigabyte Z97X-Gaming G1 Wi-Fi BK with 4770K and I am itching to go Z170 and use the Intel 750 NVMe 2.5 SSD drive. The question is: Is it worth it or should I just wait for new Intel platform that summer/fall? I have always liked Maximus Formula boards.
  13. ericepp
    ericepp What's a Dremel?
    14 Aug 2011
    Perhaps the Header connectors need to be transposed. Is there a connector for the leds behind the cover that you can flip around the opposite way? I am not an expert on this; merely offering an idea.
Tags: Add Tags
