Hardware Asus MG28UQ Review
Discussion in 'Article Discussion' started by Dogbert666, 13 Dec 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Might be worth considering if the new Vega cards can offer 1070/1080 levels of performance for less money.
    ...which lets be honest, there won't be much point to them if they can't.
  3. Combatus
    16 Feb 2009
    Yep that's just it. A 4K freesync screen is a bit pointless unless you have two AMD GPUs in Crossfire or are happy with the performance from a Fury X. That said, it's still worth considering if you're not bothered by Freesync or G-Sync and just want a large 4K screen for less than £400. Vega should hopefully shake things up a bit, though, especially in the 4K scene as Freesync is so much cheaper as well.
  4. Hustler
    Hustler Minimodder
    8 Aug 2005
    Well I'm guessing (hoping) that AMD will want to launch their Vega 1080 competitor for no more than £499, which would put real pressure on Nvidia and their ridiculously over priced 1080's.
    ..if they did that, I'd seriously consider switching to AMD and pairing this 4K monitor with one.
  5. Jan1970
    Jan1970 What's a Dremel?
    14 Oct 2016
    4K freesync might be pointless today, but monitors last a long time. I am pretty sure that it will be a nice feature to have somewhere in the next 10 years (or however long you use a monitor, my avarage display replacement us 10 years, My average graphics card replacements happen a lot faster).
  6. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    TN? I don't know guys, TN in 28" seems a bit of a bad choice in terms of viewing angle.
  7. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    i don't tend to lean left and right when sitting in front of the monitor
Tags: Add Tags
