News Asus mobo with heatpiped memory
Discussion in 'Article Discussion' started by Tim S, 6 Jun 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Someone out there NEEDS it.
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I really just wish some MFG's would either DFI it (install your own NB!) or offer cheaper boards with JUST mosfet cooling, and let us pop on our own nb/sb stuff -or at least active cool it. I hate having to peel EVERY heatsink off the damn mobo when i want to change the nb/sb sinks.
  4. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Was thinking about heatpiped memory modules a while back.. guess someone else thought about it but got the jump on me in terms of getting the idea out under their name... :p
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Looks like a very sexy board :)
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Finaly a new AMD motherboard again! like it!
    I was getting sick of the hundreds of crap intel boards
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    is this really necessary?
  8. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    probably not but I kinda like the way it looks
  9. Paradigm Shifter
    10 May 2006
    An interesting idea, but will probably gain as much market dominance as those memory modules with watercooling heatspreaders attached...
  10. Jipa
    5 Feb 2004
    That's supposed to COOL the chips? More likely to heat them up compared to having no heatspreaders at all. According to my experiences the memory chips heat up wayyyy less than those heatpipe-systems on mobos. Maybe some clockers might find it handy? Likely not as they already have proper memory-coolers and the ones on the mobo will only make it harder (or impossible) to install the sticks.
    Just a marketing trick IMO.
  11. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    Well they could always conect all of the cooling together. have the heatpipe conect the RAM, Chipset, GPU or GPUs, then have some huge fan like 2 x 120mm fans cooling the whole thing :lol:
  12. revlimit
    revlimit What's a Dremel?
    25 Aug 2005
    This would be nice if they combine this with the Asus Blitz motherboard with the watercooling for the heatpipes.
  13. kempez
    kempez modding again!
    4 Aug 2005
    I'll be honest...
    manufacturers need to accept that the hottest and most troublesome thing on a modern board is the chipset. How about making cooling that does that right and let memory manufacturers worry abou cooling thier own products?
  14. Amon
    Amon inch-perfect
    1 Jun 2007
    I'm presuming the voltages at which necessitate those heatpipes are in the 7-20 volts range, am I wrong?
  15. Guest-16
    Guest-16 Guest
    Agreed :blush:
    The X38 chipset is twice as hot as the latest VIA C7.
Tags: Add Tags
