ASUS MOCA_AR mainstream equivalent?
Discussion in 'ASUS' started by confusis, 23 Mar 2011.
  1. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Hey guys,
    I have an HP Slimline ITX board in my current build. The model is the 'HP' ASUS MOCA_AR Calcite.
    It supports:
    Intel Core 2 Duo T7x00 (Merom)
    Intel Core 2 Duo T2x00 (Yonah) up to T2700
    Intel Core Solo T1x00 (Yonah)
    Intel Celeron M 4x0
    I'm wondering if there was a very similar board that ASUS produced for mainstream consumption that I could maybe use the BIOS from to enable my board to fully support the t5300 CPU that I am using..
    (The CPU works in the board although it isn't listed as supported, same with the T2080 Pentium Dual Core cpu that I was using previously. I am however probably missing some functionality and there maybe a performance degradation)
  2. Guest-16
    Guest-16 Guest
    You can't generally usually inter-swap the BIOS on any board because they are coded specifically for the hardware within. Because it's a niche board I would not have expected a retail version of it. I also think it's too old school now too: no 479Ms are even listed on any of the ASUS sites now :blush:
  3. confusis
    5 Jan 2006
    Aw damn. I can't use the HP bios update as my system doesn't meet spec apparently (not vista, not a fully supported cpu i assume)
    Thanks for your help though!
  4. cyborg28
    cyborg28 What's a Dremel?
    15 Mar 2011
    Moca-ar Bios and CPU compatibility.
    Hi Confusis,
    The T2080 I had worked fine and was recognized and there were no error messages.
    I'm not sure what bios revision I am on, but I did check and it is not the latest.
    I have used T7200, T2080 and T2250 and none have thrown an error on boot.
    I'm kicking myself for throwing away a copy of Vista, I have the same problem cant get the mobo to update bios.
    If I get a copy and get it working I will let you know and you can BT a copy of vista or I can mail one to you.
    Let me know if you figure out a win7 or dos bios update trick!
    Thanks,
    Cyborg
  5. confusis
    5 Jan 2006
    Tried everything in Windows 7, basically I gave up! I did manage to extract the driver file from the HP installer, so I could do that manually if I wished. Have moved on to a new build though :D
  6. cyborg28
    15 Mar 2011
    Confusis -
    What Bios versions do you have?
    I Have 3.07 and 5.12
    3.07 Works ok, but there is no speedstep, my proc is always at 2.0GHz and ~1.25 Volts
    Resuming from s3 in mac OS results in system freezing after a few minutes esp if playing video (not sure if this is bios related but it is what I am trying to fix).
    5.12 Bluescreens Windows 7 and leaves me with no ethernet in MacOS X 10.6.7 but speedstep works for the 1.5minutes the board works in windows, 1.0GHz and ~0.85 Volts.
    I could try reinstalling win 7 after the bios update but I only use the computer as a Mac.
    I am Using AFUDOS and I extracted the 5.12 rom from the HP installer using winrar.
    Do you still have your moca-ar? What is your new project?
    Cheers,
    Cyborg
