Hardware Asus OC Station Review
Discussion in 'Article Discussion' started by Tim S, 6 Aug 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. ry@n
    ry@n Minimodder
    31 Aug 2005
    At first it seems a lot of money but its pretty packed with features. Its a real shame it isn't universal.
  3. lewchenko
    lewchenko Minimodder
    17 Dec 2007
    Lets face it, if you are buying a Republic of Gamers motherboard and no doubt a high end CPU / memory combo to go with it then you are 'loaded & minted' in the first place. Another £110 for this on top is quite frankly... peanuts.
    If I owned a ROG board, then I would consider this. For general overclockers though (like me).. once the overclock is done then it just gets left that way.... for ever ! I could potentially make use of a 'quiet mode' profile though...
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    But BIOS tweaking gives me back childhood memories! Why would I want to avoid that?
  5. poldo
    poldo What's a Dremel?
    31 Jul 2009
    just tested this on Crosshair III Formula; it works pretty well. Its not just an OC station but a fan controller as well. The fan header with thermal sensor header on the motherboard works with this, too.
    Btw, I'm also a reviewer from a local review site in the Philippines. :)
  6. dolphin-promotions
    dolphin-promotions What's a Dremel?
    12 May 2009
    It actually sounds quite decent.
    They should bundle it with a ROG board at a discounted price. So maybe a Asus Rampage II Extreme + OC Station for £300.
  7. ry@n
    ry@n Minimodder
    31 Aug 2005
    I wonder if it could be modded to work from an interal USB header with some custom software, if only to use it as a fanbus and to use the screen for displaying pictures and video (if fast enough).
  8. The boy 4rm oz
    10 Apr 2008
    I don't see the point.
  9. tin can
    tin can What's a Dremel?
    5 Aug 2009
    I've not got started with overclocking yet (it'll happen soon, though!) Once I have, I think I would only be interested in something like this if it could be used on all future motherboards - or at least all the high-end ones - not just the one I had at the time. They might want to re-think the wording on that screenshot though, inviting you to locate an extra fan "at backside"! :p
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    That seems a little... draconian.
  11. DraigUK
    DraigUK Minimodder
    9 Apr 2009
    £100+ for this ....
    ......or 30 mins in the BIOS and less than a tenner on a fan controller.
    .....hmmm :naughty:
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    why would you want to fit something that looks like a 1980s hif-fi to the front of your PC?
  13. Guest-2867
    Guest-2867 Guest
    Pah, I have wire OCD so this would never make it into one of my systems lol
  14. Guest-2867
    Guest-2867 Guest
    Because the 80s were the best!!
  15. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    I just purchased a ROG board, the rampage II gene, does not mean I am laoded, I am far from it, a poor studant. THe product does seem pointless though, the whole point of ROG boards is they provide a excellent platform for bios overclocking, so you dont need somthing like this.
  16. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    "However, while BIOS overclocking is the best option (you can’t disable Spread Spectrum with the OC Station"
    What difference does spread spectrum make?
  17. wyx087
    15 Aug 2007
    hum, it allows reading of temperature prob on the motherboard/CPU, and it allows to adjust fan speeds.......
    does it allow to set automatic fan profiles, such that the fans connected to it will speed up when system temperature goes up?
    i'd buy without heartbeat for a cheaper (£30 to 40 range) version with the above feature.
  18. perplekks45
    9 May 2004
    There is a reason the 80's are dead.
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Would have been nice to see the OCing part of this device in action compared to traditional bios tweaking and what not, versus just saying what you achieved.
  20. Otto69
    Otto69 What's a Dremel?
    6 Oct 2007
    So what the heck does this thing actually DO?
Tags: Add Tags
