asus p4p800 problem
Discussion in 'Hardware' started by kingabs, 26 Feb 2004.
  1. kingabs
    kingabs Minimodder
    31 Jan 2004
    ok when i install my memory into my pc it crashes and gives me the blue screen of death if i have more than 1 stick of ram in it is this a problem with the p4p800 mb?
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    its most likely that one of the sticks is faulty, or that they are unrealiable. What cpu is in there? what make/model/speed/timings are the memory sticks? are they identical?
  3. Mister_Tad
    27 Dec 2002
    as above
    thats not a P4P800 problem, thats a memory problem
    try swapping round the sticks (ie use the one that makes it crash on its own)
    if they arent identical (usually best to buy them in dual channel packs) then that can also cause problems when trying to use them dual channel
