Asus P5B Deluxe WiFi-AP Edition
Discussion in 'Article Discussion' started by WilHarris, 3 Aug 2006.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. customh
    customh conflagration.
    22 Oct 2005
    1st!! woot for good mobo for conroe!!
    EDIT: I didn't see, is there an actual push button for CMOS reset?
  3. Renoir
    Renoir What's a Dremel?
    19 Jul 2006
    This board was mentioned in my thread
    onboard sata & esata compatibility
    and was wandering if you'd figured out why 2 of the ICH8R sata ports are black instead of being red like the other ports?
  4. customh
    22 Oct 2005
    raid stuffs maybe?
  5. Guest-16
    Guest-16 Guest
    Nope, nothing in the manual or drivers about them.
    Best bet is to try and dig through the Asus site.
  6. cereal_killer
    cereal_killer What's a Dremel?
    7 Oct 2005
    no overclock testing ?
  7. Guest-16
    Guest-16 Guest
    Last page.
  8. xPaladin
    xPaladin What's a Dremel?
    3 Aug 2006
    Just one IEEE1394 on a deluxe mobo?
    Not bad, but for an Asus deluxe mobo I was expecting to see two IEEE1394s, similar to the A8N32s. Or did I miss something?
  9. Tim S
    Tim S OG
    8 Nov 2001
    Hi and welcome to the forums.
    There is one IEEE1394 Firewire port on the back IO panel above the eSATA port, and there is another available via motherboard pin-outs (expansion bracket supplied), making a total of two.
    Hope this helps :thumb:
  10. customh
    22 Oct 2005
    cmos reset pushbutton???? Is there one????
  11. Tim S
    Tim S OG
    8 Nov 2001
    No, it's a jumper
  12. customh
    22 Oct 2005
    Thanks tim
  13. scq
    scq What's a Dremel?
    4 Mar 2005
    Yeah. What's the overclockability on this board? So far, it seems like the only absolute options for any Conroe overclocker is the pricey P5W DH Deluxe, and to some degree Intel's "Badaxe" (I could never bear to buy something called 'BadAxe' myself), as it seems though every Conroe reviewer are using those boards for tests and overclocking.
    They may work well, but not everybody's got the budget for such boards, and it doesn't make sense if your E6300 cost less than the motherboard itself.
  14. Tim S
    Tim S OG
    8 Nov 2001
    Read the final page...
  15. xPaladin
    3 Aug 2006
    @Tim, Thanks, and thanks. Cleared that right up. ;)
  16. Latoron
    Latoron What's a Dremel?
    1 Jul 2006
    Will this board have SLI support or will the Intel 975x boards have SLI support?
    I'm not sure which chipsets will have SLI support, but alot of people are saying that in a future BIOS upgrade some boards will have SLI support. I'm just curious if this board will be one of them.
    To my knowledge, this is the only board with Intel C2D board that had SLI support. Chipset is NF4 SLI X16
    http://www.newegg.com/Product/Product.asp?Item=N82E16813131031
  17. Tim S
    Tim S OG
    8 Nov 2001
    This board doesn't have any multi-gpu support at all.
    At the moment, there is one nForce4 SLI X16 chipset that supports Core 2 Duo and that is the only one to support SLI and Conroe at the moment. NVIDIA is releasing nForce 590 SLI later this month, and board partners should be selling by the start of next month. At the moment, it's unclear whether i975X will support SLI - I've heard mixed responses from both sides of the fence. I guess time will tell on that front.
  18. Krikkit
    21 Jan 2003
    Great review - nice looking board too, plenty of features for those not fussed for multi-GPU.
    :rolleyes:
  19. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    mamouth? mammoth, you mean :p? (review blurb on the front page)
  20. Latoron
    1 Jul 2006
    So this boards multi-gpu is undecided, odd.
    In the latest Maximum PC magazine, they built their new dream machine and they were using an Intel 590 mobo along with 2x 7900GTX, yet they did not specify who manufactured the board. I'm hopig SLI boards will come out soon.
    I hardly call it fussing - I just crave performance :lol:
Tags: Add Tags
