Hardware Asus P5Q Deluxe: Intel P45 has arrived
Discussion in 'Article Discussion' started by Tim S, 28 May 2008.
  1. Relax
    Relax What's a Dremel?
    2 Jun 2008
    Are analogue and digital audio outputs working simultaneoulsy
    I would like to buy this board if the analogue and digital audio outputs can be active at the same time. I would be gald if anyone could confirm this.
  2. RAIDer
    RAIDer What's a Dremel?
    3 Jun 2008
    I've noticed an error in the article. "Also, you can't use the two DriveXpert sockets as normal SATA ports, so basically you end up with only five out of eight that are usable due to the layout."
    I've had a chance to play with the P5Q. The DriveXpert sockets are setup as "normal SATA ports" by default to provide 7 SATA ports.
  3. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    Sorry for the bump, but I have a question about this motherboard's layout.
    Will a Creative X-Fi Platinum card fit on the upper PCI slot, or will the RAM stand on its way?
  4. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    I really wish we could retest this mobo with 1066 DDR2 RAM, using a more recent Bios
  5. fastboxster
    fastboxster What's a Dremel?
    3 Nov 2008
    real geeks use slipstream on XP
  6. kryark
    kryark What's a Dremel?
    19 Jan 2009
    An assortment of flatering comments; so here's a reality check.
    Take a look at the ASUS forum for this board and you'll find an increasing number of people who are very unhappy with it. One of those was me and after 2.5 weeks of trying patiently to get it working I gave up. Not only did it not work, the ASUS support was useless and really didn't do anything helpful. Please note that I was not overclocking, I was just looking for a stable high end configuration.
    On paper, this board looks good. In reality, it's a pain to keep running and ASUS seem to have already left it behind. You may also like to consider many of the posts which show that many of the board's features cannot work together... don't be fooled by the specs.
    I've been an ASUS owner for years, but I'm now the happy owner (36 hours without a failure) of a Gigabyte EP45-UD3P. BTW, the same Powersupply, Memory, CPU (Q9550), HDD (WD Black 1TB), Video card (ASUS 9800GT) and OS (Vista 64U) are in use.
  7. Guest-16
    Guest-16 Guest
    Asus forums, like any other, are only frequented by people with issues. It's only ones like DFI Club that are "community" for overclocking and the likes.
    http://www.bit-tech.net/hardware/motherboards/2008/11/21/gigabyte-ga-ep45-ud3r/13
    We also recommended the UD3R too - great board.
    Did you just RMA it? Maybe later revisions are worse?
Tags: Add Tags
