Asus P5Q-E Not Posting
Discussion in 'Asus UK' started by antipcw, 14 Jun 2018.
  1. antipcw
    antipcw Member
    11 Jun 2009
    Bought an Asus P5Q-E off eBay. supposedly working.
    Have tried two different LGA775 processors coupled with a Be Quiet!Dark Power Advanced PSU+Bfg 9800GT PCIe graphics card+OCZ HPC Reaper OC2-8500 ram sticks, out of the case before I build it, to test it is in fact working---no POST.
    Any ideas what may be causing this before I contact eBay to ask for a return?
    Thanks for any replies/help.
  2. TheMadDutchDude
    23 Aug 2013
    What voltage is your RAM rated at? There used to be a lot of issues surrounding RAM that was 2.1v+ in order to boot. You used to have to insert another stick, set to 2.1v and then shut it down. Then insert your modules.
  3. Vault-Tec
    30 Aug 2015
    I had similar issues with an Asus board of the era. When using 8gb ram you had to insert/reboot one stick at a time. DD2, as well.
    Take all of the memory out then clear CMOS with the jumper (or a button if you have one). Then try and boot it on a single stick.
