Motherboards Asus P8P67 - different flavours/prices?
Discussion in 'Hardware' started by neil_b, 8 Jan 2011.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    I want to buy an Asus P8P67, for use with an SB 2500/2600K, however looking at what's available there appear to be at least 4 different versions, the most expensive of which appears to come with a USB header box.
    Apart from the version (the most expensive) with the header box, can anyone tell me in a nutshell what the differences are between the different flavours, or if I buy the cheapest one is the only difference that it doesn't have the USB3 header box? For a £50 GBP difference it seems unlikely???
    Thanks
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    As far as I'm aware, the Pro + Deluxe support SLI, whereas the others only support Crossfire. The Deluxe also as on-board power on and reset buttons for test benching.
  3. neil_b
    neil_b Minimodder
    20 Jun 2009
    Just seen a post with the differences, so I'm sort of "locking" this thread - unofficially!:wallbash:
