Hardware Asus P8P67 Review
Discussion in 'Article Discussion' started by arcticstoat, 12 Jan 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    I'll be interested to see if any H67 boards can compete well at stock speeds
  3. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    I'm suprised by the amount of PCI sockets still used and the fact that the second small PCI-E would be unusable with a dual slot GPU above it.
    Surely a PCI would be better under the GPU as that's less likely to be used in the future leaving more available PCI-E slots for things like adding extra USB3 connections out the back and Sata6 ports inside?
  4. faugusztin
    11 Aug 2008
  5. stupido
    stupido What's a Dremel?
    30 Nov 2009
    When I read this:
    I was :rock: but than I read:
    and I was :waah:... and stopped reading...
  6. Xir
    Xir Modder
    26 Apr 2006
    For me that's a feature, not an issue.
    There's no need for the CPU to run at 100% when I'm not doing anything intense, this is a very elegant way of overclocking if you ask me.
    Well, according to ASUS Asus-website the P8P67 does allow for CrossfireX.
    I'd recommend the P8P67-Pro or upward which do support SLI and probably don't have the issue of the dumbed down second PCI-E slot though.
  7. Xir
    Xir Modder
    26 Apr 2006
    Just checked, the -Pro is just 20euro's more... what idiot sent the lowest common denominator to a tech enthousiast site? :D
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    I agree, the Pro is the real price-point competitor to the GD65, not the base model.
  9. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Isnt the test setup wrong for the cpu? Looks like the x980 specs not the 2500k. Says 12mb cache and 133 qpi.
  10. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Yup, the Pro does both xfire & SLI. However, you still only get x8 PCI-E in xfire/SLI.
    "2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)"
    Source: http://uk.asus.com/product.aspx?P_ID=HMMvTCuBcZLfu2YL&templete=2
  11. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    You should of reviewed the P8P67 PRO or P8P67 Deluxe as they have a better spec especially with power supply/modulation.
    Anyone looking at this for a purchase go for the PRO version.
    http://www.legitreviews.com/article/1500/1/
  12. bogie170
    11 Aug 2008
    +1 on that. Lame standards by reviewing it Bit-tech.
  13. D B
    D B What's a Dremel?
    11 Apr 2004
    Doesn't look like a Deluxe or Pro is needed unless you want SLI, and it's still not going to be at 16x
    I'm not going to need SLI so it looks like this is the one I'll be getting (thank goodness I resisted the urge to upgrade a long while back)
    Thank you Bit-Tech for testing " the lowest common denominator " and showing that this board is fully up to the task of overclocking SandyBridge to 4.9Ghz
  14. smugboy
    smugboy What's a Dremel?
    30 Aug 2010
    I've just bought one of these boards and am awaiting delivery. Any idea if I will have trouble mounting a Gelid Tranquillo to this board as I've ordered one of those as well?
  15. Xir
    Xir Modder
    26 Apr 2006
    Just for Interest, did you test what the "TPU chip" automatic overclocking did for your voltages and speeds compared to your manual overclocking?
  16. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    It is needed for CF as well. The second slot on this MB only runs at 4x speed (WHY? FFS).
    The overclocking on the Asus bios also makes perfect sense. You are only adjusting the turbo frequency anyway so that's what Asus show.
  17. law99
    law99 Custom User Title
    24 Sep 2009
    PCI slots are useful for audio expansion cards for recording and such, so I'd rather not see them go. Plus crap that you can buy at maplin; generic expansion hardware.
  18. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    pci slots should be on the final phasing out stage, ie one at the end of the board, like they did with isa slots
  19. mrbens
    15 Aug 2009
    I've just recently bought a new sound card and on my current mobo I would have prefered to get the PCI version but for future proofing I went with the PCI-E version instead. For my next mobo upgrade (won't be a couple of years) I'd prefer just PCI-E and no PCI.
  20. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
Tags: Add Tags
