Hardware Asus P8P67 Review
Discussion in 'Article Discussion' started by arcticstoat, 12 Jan 2011.
  1. karagiosis
    karagiosis Greed
    17 Jan 2011
    On the other hand, as i going to buy a new pc i'd like to know which coolers don't fit in these motherboards besides the titan fenrir. For example i'd like to buy a thermaltake Frio but i don't know if it will suffer from the same mounting obstacles...
  2. dandym
    dandym What's a Dremel?
    17 Jan 2011
    does this board have an HDMI port?
  3. Xir
    Xir Modder
    26 Apr 2006
    Yes, seeing the X58 Sabertooth outperformed it "normal" brother...a comparison to the P67 Sabertooth would be highly interesting.
    Also, the discussion about the "Tactical Vest" is bound to be great forum-material:D
  4. ardz
    ardz What's a Dremel?
    10 Jan 2011
    Agreed. I'm not paying an extra 20 quid or whatever for somthing I know for a fact I'll never ever use! :thumb:
  5. markie
    markie What's a Dremel?
    21 Jan 2011
    Dunno if this is a common problem or it's just a one off but after updating the BIOS to 1003 my system sat at the press F1 to enter setup screen and refused to do anything further... Oh no, I figured I'd broken the thing before it was 12 hours old. As a last hope I swapped the USB keyboard for an old PS/2 one and it worked. 1003 also fixed an issue of the board not detecting 2 of the 4 DDR3 modules.
  6. dim5b
    dim5b What's a Dremel?
    1 Feb 2011
  7. dim5b
    1 Feb 2011
  8. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Have you not seen the article about this on the main page?
    Tweakguides sums it up nicely:
  9. lexloofah
    lexloofah What's a Dremel?
    2 Feb 2011
    OK, so say if somebody has one of these on its way in the post (doh!) and needs to use 4 sata ports. Can I use all four 6Gbps at the same time (only one device is actually 6Gbps the other devices are 3Gbps) and avoid the whole problem?
    Thanks in advance.
  10. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    Well I had slowly but surely been building up to the upgrade that is sandy bridge.
    P8P67
    8gb Corsair Vengence DDR1600
    2500K
    All to be fitted in the TJ07, with new pump and heatkiller block and triple rad .
    All was going well everything I ordered landed (just) before good friday and away I went......
    System built - first hurdle, full format require for Win7, including removal of any partitions not compatable with EFI - for me that meant all of them so I lost some stuff not being fully prepared.
    Okay thats not so bad - OS DVD corrupted so had to buy another (great).
    Okay now all installed and running and looking good - time to tweak the BIOS, linx stable at 5.1ghz temps around 74degs - so was just running WoW and went out for a cig... contemplating that 74degs (and the associated voltage jump when it went to 5.1ghz full load) was too high and that 4.9ghz would be more practical.
    Came back to find PC completely shut down and has not re-started since - not even fans running when I powered it up - all I got is a single lonesome green LED telling me there's power to the board :eek:hmy::mad:
    So now I take the time to read about the board, seems things like this are not uncommon, but to make sure, I tried a diff PSU, Graphics, RAM (diff sticks and diff sockets) - leaving just the cpu in and firing it up, firing up a naked board - all comes back negative situation exists.
    The only silver lining is that I have to go to the works office to have my laptop replaced, this is in Wigan, Scan is in Bolton (15mins away) so while my laptop is having itself set-up and data copied over I am going to take the board up there - buy a Gigabyte UD4 and swear never to go Asus again.
    This is the P5Q scenario all over again for me - u'd of thought I would of learned, but the review in CPC on the Asus board had all the words in I wanted to see coupled with a great price.
    Now here I am digging up an old X38 board with a E8500 reloading win7 just to get me by until then.
    Thanks again Asus for 'rolling me over' and shafting me without even the courtesy to use any lube.
  11. Dackman
    Dackman What's a Dremel?
    23 Mar 2011
    Just brought a B3 revision, fantastic board
  12. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    old thread is old.
  13. maverik-sg1
    18 Aug 2010
    You know if people are reading these reviews because they are thinking of buying the product then (so long as product s still current) posting comments regarding such things as failed units and things to watch out for - it provides more information to people to ensure that their experience is a better one than what I had.
    So your comment, although chronalogically correct, is not really needed.... is it? No hard feelings and please don;t take offence to this - but spam is spam as far as I can see.
    Just an update - took the failed board and CPU back to Scan today - the tech guys were kind enough to make time to test both items separately whilst I waited. Both were found faulty and were replaced within 45mins of me turning up unannounced on their doorstep - best service I ever received from any PC component store/site - Thank you guys :)
  14. UrbanSmooth
    UrbanSmooth Surround Gamer
    27 Apr 2011
    Love the color scheme of this board!
    It would be great to do a matching water cooling tubing and sleeving build with this.
  15. Dennybrig
    Dennybrig What's a Dremel?
    17 Jun 2011
    Help with P8P67 M Pro
    Maverick:
    Bro, did you have any luck in making your asus board to work?
    It just happened the same to me, only the green LED turns on, not the fans or anything else
  16. steve30x
    steve30x What's a Dremel?
    31 Aug 2008
    Where did you bring it?
Tags: Add Tags
