Motherboards Asus P8Z68-V, RAID & Intel Smart Response
Discussion in 'Tech Support' started by cmberry20, 15 Aug 2011.
  1. cmberry20
    cmberry20 Mad Scientist
    16 Jul 2007
    I'm going to be upgrading my current system LGA775 system to an 1155 system with the Asus P8Z68-V (NON PRO) motherboard.
    However, in my current setup I have 2 X Samsung 1GB F3 hdds setup in RAID 0.
    I will wipe the drives & restore using Acronis later, however, what would give me best performance for the future:
    Install Windows 7 on the 2 X 1GB in RAID 0 using the 2 (& only 2) x SATA 6Gb/s ports. Even though the drives are 3Gb/s. Then, in a few months, I wish to add a ~40GB SSD as a Cache drive using Intel Smart Response - however, I will only have a spare SATA 3Gb/s port left on the motherboard, will this be ok?
    Or would I be better off & setup the RAID 0 using the 3Gb/s SATA ports & keep the 2 X 6Gb/s SATA ports for the SSD drive as this requires the most through put.
    oh yes, even though i cant find anything to the contrary, but I'm assuming that its perfectly ok to have a RAID 0 setup & use/add Intel Smart Response??
    Any suggestions are welcome.
    Cheers.
