Motherboards Asus P8Z77-M PRO - no boot?
Discussion in 'Hardware' started by tsutton, 28 Oct 2012.
  1. Pointy
    Pointy What's a Dremel?
    15 Nov 2008
    In the past I have had systems power up, although not post, when I have forgotten to connect the 4 pin PSU header. Just read the manual, check the other switches on the mb, EPU/TPU, probably wont make any difference, but can't hurt to try.
    Les
  2. tsutton
    tsutton Minimodder
    29 Aug 2003
    The 4 pins are already plugged in - nothing.
    I have checked both EPU/TPU switches - both are off.
  3. Pointy
    15 Nov 2008
    Try reset the CMOS and then power on.
    Les
  4. tsutton
    tsutton Minimodder
    29 Aug 2003
    Did that loads of time - nothing.
  5. Pointy
    15 Nov 2008
    I quick google, show other people with the same or similar problem, saying they had to reset CMOS or remove battery to get the system to power on. I would contact Asus Tech Support( I have found them really helpful in the past) and they will advise about RMA.
    Les
  6. tsutton
    tsutton Minimodder
    29 Aug 2003
    The board is a few days old... should I RMA it to Scan as it seems to be DOA on arrivial?
  7. Pointy
    15 Nov 2008
    Well in the past I have contacted Asus first, when I have had a DOA board.(It has only happened twice in several hundred builds) They have then advised me to RMA the board. You could probably go straight to scan, I always think it's more definitive if you have spoken to Asus first.
    Les
  8. tsutton
    tsutton Minimodder
    29 Aug 2003
    The more I research about this motherboard, the more I see about it not working and also DOA too, so I guess I got unlucky with this motherboard then!! :(
    Time to get this swapped out... hopefully with little hassle!
    To all - thank you very much for your help & advices. Hopefully I wilolo be back up & running with the new setup very soon!. :D
  9. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The motherboard is supposed to power up even without a CPU or any RAM inserted. The board is dead, RMA it.
    For future reference, you can also test a PSU without plugging it into a motherboard by shorting the green wire in the ATX connector to a black wire (e.g. with a paper clip) and then connecting the PSU to mains. ;)
  10. tsutton
    tsutton Minimodder
    29 Aug 2003
    That's what I thought too. I took everything off, leaving just the PSU connected to the motherboard. Upon powering on, the PSU fan doesnt even spin at all. That's where I knew the board is DOA. Thanks for the additional confirmation.
    Yeah, did that as well. Confirmed working fine.
    Cheers, I'm just hoping the replacement will be quick!
  11. tsutton
    tsutton Minimodder
    29 Aug 2003
    RMA accepted. Going back to SCAN tomorrow, hopefully getting a replacement soon.
  12. tsutton
    tsutton Minimodder
    29 Aug 2003
    Now that the replacement motherboard is on the way back, I am interested to know the answer above.
    Will the 4 pins be enough for this motherboard? What will it give me if I plug both pins (2 x 4 pins, making 8 pins) - will it give me more stable system? Or makes no difference (apart from using more power)
    Just curious... thnaks.
  13. mm vr
    18 Nov 2007
    It will likely make no difference whatsoever, but if you do have an 8-pin cable, why not plug it in?
    The four additional pins are just soldered in serial with the first four in both ends, so the only difference is that a single wire and connector pin has to carry less current. However, molex connectors and wires are rated rather high, and four pins should be perfectly fine for a <100W CPU. But again, why not if you have the wires?
  14. tsutton
    tsutton Minimodder
    29 Aug 2003
    OK, thanks. :)
  15. RocketPotato
    RocketPotato What's a Dremel?
    4 Sep 2012
    I suggest RMA'ing it unless you have a spare PSU around which you can test with.
  16. tsutton
    tsutton Minimodder
    29 Aug 2003
    May want to read back this thread. :p
    Cheers
  17. RocketPotato
    4 Sep 2012
    Ha, sorry, my bad :D
  18. tsutton
    tsutton Minimodder
    29 Aug 2003
    Have put together the replacement motherboard - all good now.
    Thnaks for your help!! :)
