Hardware Asus Radeon HD 5870 Voltage Tweak Review
Discussion in 'Article Discussion' started by Tim S, 20 Oct 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    <3 You guys for including an 8800GT on there. I can actually see how much of a performance jump I'd get if I upgraded!
    What version of SmartDoctor are you running? I've got 5.34 (I think) and that allows saving your Overclock between reboots. Unless you meant Overclocks + Voltage settings - I have no idea if my version supports that.
  3. bagman
    bagman Minimodder
    18 Apr 2009
    why didn'y you benchmark the asus 4870 oveclocked in games? i want to see how good this card is at overclocking and the performace boosts
  4. eek
    eek CAMRA ***.
    23 Jan 2002
    I wondered that too. I get that the card doesn't come overclocked and not all cards will clock equally, but given that this product is aimed at overclockers it surely makes sense to run it overclocked in the benchmarks - how many people are going to buy this and run it at stock?
    Looks like a nice card though. Every day we fail to see any sign of activity in the nvidia camp is another day for AMD to pull ahead!
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    You mean those Crysis performance graphs on the "overclocking" page showing stock vs overclocked performance we're enough?
    Realistically though, the overclocked settings will only have an affect under certain cirumstances. Some games will be core clock limited, other more memory dependant, and others still will be driver based when it comes to performance. The Overclocking graphs we've included give you an idea of what we got from the card, but there's no way to say you'll get the same due to differences in the GPU between cards.
    The stock performance we've given here is what the card WILL deliver, not what it might deliver if you get the voltage tweak right.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    It looked very promising until I saw the temperature. Without better/water cooling that beast it is a nice proof of concept, nothing more nothing less. I don't think I want a card that goes all the way up to 80+, maybe even 90 degrees.
  7. stonedsurd
    11 Mar 2009
    You've never owned a reference HD4850, have you perplekks?
    Those babies run right up to 90C without any throttling. I think ATI chips just run hotter because they can handle it, unlike nVidia's bull**** chips that die if they go over 65C.
  8. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    This does indicate that with some process tweaks, AMD will have some room to play with in terms of GPU speeds once Nvidia releases its new product. That should be interesting. :)
  9. perplekks45
    9 May 2004
    No I haven't, true.
    My 8800GTS/640 runs nicely <70 and I like it. :p
    Still I think fewer heat sources in a system are a good thing. And Roto might be right there: New process, cooler, very good performance, low heat >> me likey!
  10. MorpheusUK
    MorpheusUK a Noob that knows something
    24 Sep 2009
    What's to stop one from flashing their other partner 5870 BIOS with the Asus one to unlock the over-volt potential?
    Just a thought if it's even doable.
  11. Baz
    13 Jan 2005
    erm, we couldn't possibly comment on whether this was possible....
  12. perplekks45
    9 May 2004
    Voiding your warranty? :D
  13. Er-El
    Er-El Minimodder
    31 May 2008
    The STALKER: Clear Sky looks like a real power drainer. I own the HD4850 but it ran at minimum 10fps on that card! :(
  14. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    I wish I had £300+ I could spend on a 5870.
  15. -VK-
    -VK- Lurker
    11 Oct 2007
    1) You'll void your warranty.
    2) The card I tried to do it on ended up as a paperweight.
  16. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Theres probably an Asus chip on there somewhere....like they have on their motherboards....
  17. p3n
    p3n What's a Dremel?
    31 Jan 2002
    For a side grade in performance?
  18. Baz
    13 Jan 2005
    Nope, physically it's just the same as any other HD 5870 - all the Asus tweakery is done in the VBIOS.
  19. wyx087
    wyx087 Multimodder
    15 Aug 2007
    i wish Asus gave out these instead of gtx285's.
  20. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    my 9800GT runs at up to 105C at full load and has done for months (folding)
    there rated to 125C
Tags: Add Tags
