Hardware ASUS Radeon R9 290 DirectCU II OC Review
Discussion in 'Article Discussion' started by Meanmotion, 3 Mar 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    Nice review. This seems like a great card for great value for anyone who lives outside of the US and Canada! (Sorry North Americans).
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    Would it fit in a Corsair 250D?
    I thought I saw somewhere that the heat pipes on these CU models make them too high...although the ones on this don't seem to protrude as much as some others I've seen , maybe they've had a design revision???
  4. tozsam
    tozsam What's a Dremel?
    11 Jun 2010
    which other modified cards whould have the extra power components on them. The cooler doesn't matter to me as I intend to watercool, I just want the best components for overclocking
  5. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Bought one of these for my little brother's build a few days ago. It also happened to be the cheapest 290 I could find at the time, which made it even more wonderful.
  6. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    It looks like there's enough room from the pics I've seen but I don't have the 250D in the labs anymore so I can't say for sure, sorry.
    It varies from board partner to board partner. Most partners have a pure reference version, which won't be modified. Then some of the custom cooled ones will use the standard power components, while some (like Asus here) will use their own modified ones. And naturally each one that uses their own will tell you their components are better than the rest. As for the Asus range, both DirectCU II R9 290 versions (the OC and the non-OC one) use the customised power circuitry. Custom PCBs may mean that standard waterblocks won't fit, however, so bear that in mind as well!
  7. Dogbert666
    17 Jan 2010
    Antony has measured the distance between the top of the PCI bracket mount and the roof and says it's at least 45mm. And by my own measurements the Asus card extends about 40mm past the edge of the PCI bracket at the tallest point on the heat pipe, so I think you're just in the clear.
    Also, going by the specs on the Asus website, this card is 1.5 inches taller than the reference card (which doesn't extend past the PCI bracket edge at all) and 1.5 inches = 38.1mm
    Hope that helps!
  8. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is it just my poor eyes, or are only three of heatpipes making contact with the core ?
  9. Dogbert666
    17 Jan 2010
    Nope, you're right. Derp, sorry, fixed now! Thanks for pointing it out.
  10. Hustler
    Hustler Minimodder
    8 Aug 2005
    Thanks for that....I'm a bit paranoid about being 100% certain that parts will fit before buying.
    Nothing gives you that sinking feeling quite like unboxing a new piece of hardware only to realise it doesn't fit and your now in 'Returns policy' hell for the next 2-3wks.
  11. Corky42
    30 Oct 2012
    Sorry i didn't mean that to come across as information lacking from the review, it was just me vocalising a wonderment of how much better it would perform if they all made contact, or would it not make a noticeable difference.
  12. Dogbert666
    17 Jan 2010
    No worries - I'm just surprised I missed it since I took the thing apart and took photos too! It is strange that they don't all make contact, I guess they found it was better to use thicker heat pipes where only three make contact rather than five thinner ones.
Tags: Add Tags
