Cooling Asus Rampage 2 Extreme North/South Bridge
Discussion in 'Hardware' started by Wilkirich, 16 Dec 2009.
  1. Wilkirich
    Wilkirich Don't tell them your name Pike!
    27 Nov 2009
    Hi started testing in ernest Prime95 - to ensure stability had it running for 15mins
    at 4.14 cpu stabilised at around 64-65 deg North/South bridge went from 36 -38 to
    52-54 deg. This is with the CPU cores at 100%...........if I use pc normally temps drop to mid 40's. Question:- What temp are the R2E bridges safe at? my concern is the board's cooling seems to rely on waste air blowing over heat sinks from a std CPU cooler.........my Mega Shadow with push pull fans just directs the warm air straight out the case......not over the sinks. My case has good cooling with 5 120mm fans........and appears to run very cool but there is little direct air movement over the bridge sinks.........I am keen not to fry my pc and need good reliability for next few years.
    Hope you can advise
    Richard
    i7 920 DO
    Mega Shadow + 2 Sharkoon PWM fans
    6 GB Supertalent 2000mhz DDR3
    850w Seasonic Modular PSU
    Adaptec SCSI 2960 with 140GB 15k drive
    GTX 260 BFG Overclocked
    Stock 26 Deg idle
    7 Ultimate 64bit
    4.14ghz @ 1.38 v @ 65deg Prime95 15mins
    1.64v DDR
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Usually the bridge chips are designed to withstand high temps, many board will go on for years and years even when the bridge chips are too hot to touch. That said its still good to keep the temps as low as possible, is there no where you can mount a fan to blow onto the bridge chips. Usually people have fans mounted at each end of the case so that air is stucked in on one side and blown out the other so you get a flow of air going through the case which will run over the bridge chips.
  3. Wilkirich
    27 Nov 2009
    Hi thx for replying...........things are a little tight...........but there is good airflow
    in case......but Megahelems is so huge it kinda disrupts airflow around n/s bridge.
    I will try and fix a couple of 40mm fans in..................directly over.
    Meanwhile, the mid 50's does drop to mid 40's when not running prime...........
    I'm sure this really stresses things.
    Richard
  4. riekmaharg2
    22 Feb 2009
    Thats actually pretty good, mine is at 40 at idle even with a fan directly on it! lol
