Hardware Asus Rampage III Gene Motherboard Review
Discussion in 'Article Discussion' started by Sifter3000, 19 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Wait... the 6Gbps ports were SLOWER?
  3. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
    I want this in my Antec 300
  4. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Its because we tested with a 3Gbps drive, its mainly just a test to check they work and aren't broken. Now we've got a reasonable 6Gbps drive in the form of the Crucial C300 we'll actually be able to test the raw speed of then in the future. We'd have done it before but while motherboards have had 6Gbps sockets, there hasn't been any decent 6Gbps drives to test them with.
    With a 3Gbps drive the 6Gbps sockets actually return slower speeds, as they are provided by a third party chip as opposed to integrated into the Southbridge.
  5. poldo
    poldo What's a Dremel?
    31 Jul 2009
    It will not look good in your Antec, 'had a chance to test the maximus II gene in an antec 300 and it just didn't look right. :)
  6. Kojak
    Kojak Who loves ya baby
    3 May 2010
    I luv it, makes me wanna do a build devoted purely just to gaming!!
  7. Joey9801
    Joey9801 Eric the Half a Bee
    24 May 2009
    Grammar Nazi is disappointed with Bit-tech
  8. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Got tired of Asus, too many problem on past, I'm going to try Gigabyte GA-X58A-UD7.
  9. Xir
    Xir Modder
    26 Apr 2006
    How does the P6X58D-E compare to the P6T SE ?
  10. kingjohn
    kingjohn mod this sucker
    22 Jun 2010
    ive been looking to spend about a grand on a pc for the last year and ahalf , and aal this looking and not buying is doing my head-in , as you can clearly see with my spelling and punctuation , i feel like some bloke thats been to amsterdam and spent too much time looking in windows and never getting the gooodies ,frustration isnt an adequate description , but finally starting monday 9-8-10 i order my case , psu , hd , dvd-rw , and posibly OS win 7 64bit , week after that the mbrd gene iii , cpu 920-930 , and ddr3 ? , then the last bits soon after .
  11. kingjohn
    22 Jun 2010
    i order my gene 3 today along with the i7 930 and corsair c8 ddr3 ,and the asus gtx 470 , happy gamming for a bit i hope .jj7
  12. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    "I want this in my Antec 300"
    My want up my bumhole it looks that nice!
Tags: Add Tags
