News Asus refines AMD core unlocking
Discussion in 'Article Discussion' started by CardJoe, 21 Oct 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Truly, truly, awesome! Whoever gets all 4 cores up and running, stable, please tell us which CPU you have!!
  3. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    ****! That is awesome!
    As a Phenom II X2 550 owner I only wish I had of bought an ASUS mobo instead of going for a Gigabyte 790X-UD4P and its core unlocking since my chip refuses to run as a quad no matter what I do (increase voltage, decrease clock speed/HT speed etc)
    I can only hope Gigabyte and other manufacturers do something similar!
  4. simonw
    simonw What's a Dremel?
    24 Jun 2009
    Nice idea by Asus.
  5. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Bloody brilliant!
    \m/
  6. -VK-
    -VK- Lurker
    11 Oct 2007
    *beams*
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    "Asus' advantage is that if you have just one bad core, you can specify the BIOS to unlock a single, specific core to give you a free triple core that's far more likely to be stable and overclockable. Plus, it's a completely free update: what's not to like!"
    But ive been doing that on my budget Gigabyte 720-US3 for the last 3mths.......its pretty easy.
    Whats the big deal.?
  8. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    will it blend?
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    That might open the door to a new AMD system for me.
    Well done, ASUS, for inviting me to the dark side... or the light side, depending on who you speak to.
  10. Gremlin
    31 Aug 2008
    How have you been managing to do that?
  11. Hustler
    Hustler Minimodder
    8 Aug 2005
    Easy, just reset Cmos, go into ACC/NCC, set to 'Per Core', turn on which cores you want with +2%, leave the 'bad' core turned off..IE..
    Core 0 +2%
    Core 1 +2%
    Core 2 +2%
    Core 3 0
    Or
    Core 0 +2%
    Core 1 +2%
    Core 2 0
    Core 3 +2%
    Reboot.......there, you now have just turned your 550 into a Phenom II 720x3 BE
    More often than not, its Core 3 that needs to be left off.
    Works for me just fine....
  12. yuusou
    yuusou Multimodder
    5 Nov 2006
    Have you tried enabling Core 2 and Core 3?
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Pretty neat idea of theirs, but it overlooks one thing - why bother trying to unlock a "free" core, if the board for it will cost more than the difference in price of a cheaper board, and a real triple/quad core?
    Also, I can see this being used by a few shady PC shops to make magic three core rigs.
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I like magic cores
  15. buttercup
    buttercup What's a Dremel?
    27 Mar 2009
    ITS (no apostrophe)
    Also, do you really need the "no less than"?
    This is a bit misleading as, as far as I'm aware, the new AM3 Sempron(s) is/are based on the Athlon II Regor die, which is native dual core.
    I'm just nitpicking now but that would sound better as:
    All AMD motherboards that include ACC (Advanced Clock Calibration) on the SB710 or SB750 southbridge are supported
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    here in nz you're paying a difference of $30 for the unlocking board vs a similar non capable board, vs a difference of $140 for the quad core phenom II instead of the dual core. worth it if it works... even a price difference of $60 for a tricore!
    eg:
    Phenom II X2 545, 3.0GHz, Socket AM3, 32/64-Bit, Retail pack with fan $165.77
    Phenom II X3 720, 2.8GHz, Socket AM3, 32/64-Bit, Retail pack with fan $228.38 (on special)
    Phenom II X4 945, 3.0GHz, Socket AM3, 32/64-Bit, Retail pack with fan $305.61
    Sapphire PE-AM2RS740G Motherboard $131.00
    Asus M4A785-M Motherboard $160.68
  17. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    This sort of thing takes me back to the early issues of CPC when they used to unlock extra shaders on graphics cards.
  18. frontline
    frontline Punish Your Machine
    24 Jun 2007
    weeeeeeeeeeeeeeee!. Oh, i bought a quad core. Still, great news! :)
  19. Gremlin
    31 Aug 2008
    Doesnt work for me at all sadly
  20. Roca_05
    Roca_05 What's a Dremel?
    28 Oct 2009
    I'm sorry to be the one that brings bad news to you article readers but what Richard is saying in this article might not be true. I did my homework and looked for the bios on the ASUS web site and there are 4 BIOS listed there but not the specific BIOS that Richard says has the unleashing mode. I even called tech support and they told me that they couldn't confirm that what Richard is saying in this article is true. Now I only did this for my specific motherboard which is an ASUS M4A785-M. So readers please check up on your motherboard and tell us if you are experiencing this problem as well. I really got discuraged when I saw that there was no BIOS 0308 for my motherboard which means I won't be able to unlock the third core on my cpu if it doesn't boot as a quad core.
Tags: Add Tags
