Graphics Asus ROG Ares II
Discussion in 'Hardware' started by atc95, 8 Jan 2013.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    This looks incredible, *dreams of having enough money* :grr:
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Does look the business, that is for sure.
  3. rollo
    rollo Modder
    16 May 2008
    Waste of money the fact its pre watercooled suggests it is producing some huge heat amount.
  4. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Im pretty sure for most cases a £1000+ gpu is a waste of money.
  5. Guest-16
    Guest-16 Guest
    Um, ya, it's two 7970 GHz Edition GPUs under there. It's the only dual-slot 'HD 7990'. :)
  6. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    So Asus are at it? I can't remember who, but I heard that Powercolour had the exclusive rights to 7990? Or are Asus just referring to it as a 7970X2?
  7. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Not a mention of 7990, they call it the Ares II ;)
    Don't see how that's a disadvantage. Fact that it's watercooled means it's likely tamed whatever (inevitable) huge heat amount, they do claim 31 degrees cooling advantage over reference GTX690
  8. atc95
    3 Dec 2012
    It may be a huge amount of money but a dual slot cooler and a 2x7970s opens up a lot of doors in terms of insane gaming rigs in mini towers and even itx builds!
    Surely pre watercooled is a good thing! ( a hybrid between those that :dremel: and those that don't :dremel:)
  9. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    I think it's awesome. And you can always mod the CLC:dremel::D
  10. theshadow2001
    3 May 2012
    :rock:
    I love it.
  11. bagman
    bagman Minimodder
    18 Apr 2009
    Yeah this card with that cooler in a ITX case :rolleyes:.
    I think it looks ridiculous, and is that a zip tie in the second picture?
  12. atc95
    3 Dec 2012
    why the :rolleyes: it would fit in a bitfenix prodigy without too much hassle, you would just need a beefy power suppl. I believe it is a a zip tie.
  13. The_Crapman
    5 Dec 2011
    Zip tie for the win! in other pics i've seen it looks like there's a 3pin fan connection coming out of it that is looped through that zip tie.
  14. atc95
    3 Dec 2012
    It is on pre-order from OCUK now. A cool £1199, I don't understand the need for 2 of them in one system in one of the pictures.
    Link
  15. rollo
    rollo Modder
    16 May 2008
    cost is insane
    does it out perform tri sli 680s or quad sli 670s as thats what you can buy for £1199
    its not even competing with a 690 as if you vist ebay you can buy 2 690s for less than it costs.
  16. law99
    law99 Custom User Title
    24 Sep 2009
    No. But these things are always **** aren't they... like super expensive monster cables... for show.
  17. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Oh yes!!!
  18. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    I'm surprised to see that it uses a closed loop. Most people that would buy this sort of thing would be watercooling anyway, so I would have expected the stock radiator to be detachable (or an optional extra), so that the card could be incorporated into an existing loop.
    Does look awesome though, even if it doesn;t outperform cheaper setups.
  19. Guest-16
    Guest-16 Guest
    As soon as I get hold of one here I will put it in a Prodigy with P8Z77-I Deluxe :D :rock:
    You'd think, but nope. In fact, if you look at the market there's less and less high-end cards with blocks already on them because they just don't sell.
  20. atc95
    3 Dec 2012
    Greatest mini itx build ever!
