Reviews Asus ROG Crosshair VIII Formula Review
Discussion in 'Article Discussion' started by bit-tech, 12 Jul 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    £600 top end board with integrated waterblocks, but doesn't actually contact the part of the board that otherwise needs a fan on it.
    Go home Asus, you're drunk.
    xaser04 and adidan like this.
  3. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    No.
    Just no.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    This is exactly what I thought! Finally a proper reason to have integrated watercooling and they don't do it!
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    That'll be on the $999 AsRock limited production run halo product x570 mobo.
    (sadly I'm not even joking)
  6. Vault-Tec
    30 Aug 2015
    I look at the Zenith X399 release and I thought it wasn't actually that bad price wise. I mean, you got *so much*.
    This though? meh.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    While I agree £600 is too much for this, lets not forget why they can get away with it:
    £750 3950x + £600 mobo + £200 32GB RAM = Still cheaper than just an i9-9960x alone.
  8. Bloody_Pete
    11 Aug 2008
    Which one? Do you have a link?
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
  10. Bloody_Pete
    11 Aug 2008
  11. Paradigm Shifter
    10 May 2006
    £600.
    No 10GbE. No parallel 24-pin ATX. Annoying slot layout. Stupid heatsink design/layout.
    I want to like it, but the above ruin it.
  12. dec
    dec [blank space]
    10 Jan 2009
    Surely BT can get their hands on this board for a full review, even if its just 10 pages of phwoar. Its great to see EFI/BIOS screenshots with these reviews. I remember years ago deciding which mobo to buy based on the review of the BIOS/EFI. This was back when sometimes motherboards would use voltage offsets or odd names for important quantities.
    MLyons and xaser04 like this.
  13. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Just noticed this. They could have at the very least run a heatpipe down from the VRM portion of the waterblock on the right hand side. Would have probably been enough to then run passive cooling on the chipset.
    Oh you say voltage offsets. The Foxconn P45 board I am currently messing around with (Thanks again Zoon!) doesn't use an offset or direct input.. No, instead it uses a random number between 0 and 64 to denote what the offset would be. It is currently set to 8... what that is I have no idea! Might be good or it might be waaaaaay too much!. Other than that the board itself feels much more modern that its contemporary 780i SLI from XFX. At least it has all solid caps!
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Two reasons it probably won't happen:
    Bit-tech hasn't reviewed an AsRock mobo in like half a decade.
    The X570 Aqua is just a plain silly product... I mean lets face it, why would AsRock send out review samples of that to anyone? A mainstream mobo for a grand is just going to get slagged off anyway.
    If it was a X599 board for Zen 2 Ripper to take the p*ss out of the ROG Dominus that would be a different story.
  15. Combatus
    16 Feb 2009
    That's my single biggest issue with this board tbh. For the cash it's level of crazy/innovation was lacking compared with numerous other ROG boards we've tested recently.
    My thinking exactly. It had so many cutting edge/unique features and there's nothing particularly cutting edge or unique about the Crosshair VIII Formula, at least nothing that's been done 100 times before.
  16. loftie
    loftie Multimodder
    14 Feb 2009
    Why is it that all the USB type C holes on the IO cover are just regular USB size? I assumed it was a cost thing, but on a board that costs £600 I'd expect the IO cover to fit nicely around the type c port, am I missing something?
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    Keyboard, mouse, phone, printer, controller, headset, external blu ray drive and usb stick is 8? That still leaves 3 spare on the back plus 2 - 4 on the front?
  18. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Keyboard has 2, RGB mouse mat, RGB headset stand, USB fan, microphone if using a separate headset, card reader, and a header inside used for RGB strips. Can't believe you forgot the essentials.
    Corky42 likes this.
  19. RedFlames
    23 Apr 2009
    21 ports, once all the headers are accounted for [iirc]... how many do you think you need?
    It's the mid-low-end boards where they're stingy af on ports.
    For anyone who wants to check my maths -
    12 [11x Type-A, 1x Type C] on the rear i/o
    4 from the 2x USB 3.0 headers
    4 from the 2x USB 2.0 headers
    1 from the USB 3.1 header [at least i think you only get 1x Type-C port from it]
  20. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    Was it just me that took the ports comment as sarcasm then?
    Guest-44638 likes this.
Tags: Add Tags
