Case Mod - In Progress Asus ROG Line mod FINISHED!
Discussion in 'Project Logs' started by jones-965, 3 May 2015.
  1. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    Hi everybody!
    My sponsors:
    Today I started my next project, which gave the name ROG line, of course thanks to my sponsor.
    The components used:
    Corsair Air 240 white case.
    Asus Maximus VII Impact
    Intel i7 4790K
    Asus GTX 970 OC Mini
    Corsair Dominator
    Bitfenix Fury 750G
    The first step in the transformation of the front cover.
    Installation of the cut-out grille.
    The top panel modification.
    My idea!
  2. jones-965
    13 Jul 2011
    Today I continued my work with PCI-E video card riser cable connection fixture.
    To do so, 10x10 mm aluminum profile and plate were used.
  3. jones-965
    13 Jul 2011
    The new rear I/O panel of aluminium plate.
  4. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    nice work, like what you've done with the case so far
  5. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Quite like where this is going, can't wait to see the end product! :thumb:
  6. jones-965
    13 Jul 2011
    Thanks guys! :)
    Today the exterior decorative elements made it. The materials of 2-3 mm plexiglass .
    Double-sided adhesive tape
  7. jones-965
    13 Jul 2011
    Today the ROG logo were completed.
  8. jones-965
    13 Jul 2011
    Today the package arrived courtesy of EK water blocks .
    Thanks for the support!
  9. Mads1
    Mads1 What's a Dremel?
    2 Apr 2015
    Looking great so far. :)
  10. guitarhero23
    guitarhero23 What's a Dremel?
    27 Mar 2015
    You must of had fun filing acrylic by hand, I've done it. 1/10 would not do again, but will probably have to do again.
  11. jones-965
    13 Jul 2011
    Thanks mans! The Dremel Saw machine easy to work with.
    Newly arrived water blocks installed the asus maximus VII Impact motherboard.
  12. bulldogjeff
    2 Mar 2010
    Thats looking very nice. I really like the layered effect on the logos and the case... Nice work.
  13. jones-965
    13 Jul 2011
    The big ATX sized cases after now the little ones favored.
  14. wst
    wst Minimodder
    30 Aug 2009
    Wouldn't a blowtorch simplify the edge-dressing process on those cut edges to smooth them down easily? Not sure how acrylic behaves under heat but when I was working on polycarbonate (for supermarket fridges) we used to have a little blowtorch that would melt the CNC routed edges and make them lovely and shiny in seconds!
  15. jones-965
    13 Jul 2011
    Of course, the plexiglass edge to be processed. Thanks for the tip!
  16. jones-965
    13 Jul 2011
    Today I continued the project, the water cooling components were installed.
  17. jones-965
    13 Jul 2011
    Today they finished the inside panels and a test of the system are built up.
    The top panel cutout grid. :)
  18. jones-965
    13 Jul 2011
  19. jones-965
    13 Jul 2011
    Update!
    Arriving at the VGA, and got into the place and was given a new covering.
  20. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    This is going very well! Looking forward to see it finished :thumb: :naughty:
