Reviews Asus ROG Strix Z390-I Gaming Review
Discussion in 'Article Discussion' started by bit-tech, 27 Dec 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. adidan
    25 Mar 2009
    Can I be the first to applaud you for mentioning this.
    The more it's mentioned, especially in reviews that consumers use in their buying choices, the more likely manufacturers will look to address the problem.
    Guest-56605 and Mr_Mistoffelees like this.
  3. Guest-56605
    Guest-56605 Guest
    The irony, it's RGB related :hehe: :hehe: :hehe:
    adidan likes this.
  4. Vault-Tec
    30 Aug 2015
    If you install the Asus ROG software for LEDs it stops you playing Far Cry 5. The anti cheat tool goes nuts.
    Took my friend and I a while to figure that one out.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I'm not sure it's official but i think because it's not a remote exploit they think it's not worth fixing. o_O
  6. Guest-56605
    Guest-56605 Guest
    I suppose in turn, you could always adopt the attitude it's exploitable therefore not worth buying - it's a so called FEATURE that in turn causes a vulnerability which you're in turn expected to pay top dollar for...
    Yup, that's logical - NOT.
Tags: Add Tags
