Reviews Asus ROG Theta 7.1 Review
Discussion in 'Article Discussion' started by bit-tech, 24 Jul 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Paradigm Shifter
    10 May 2006
    While I think the price is outrageous, it is not "nearly £300". You clearly state it has a £250 price tag on the first page, so later calling £250 "nearly £300" is rather painful to read because you've basically fudged the price by up to 20%. >£275 I could see as described as "nearly £300". But a £50 margin of error is rather extreme.
    Also, with cables that bulky, I'd try running the wires down my back as they'd be far less troublesome. I do it with less troublesome headphone cables - it can take a little getting used to, but it is much more comfortable long term.
    I basically gave up on 5.1 (or higher) audio when Vista/7 landed. While I'll freely acknowledge that I'm not a competitive online gamer, stereo has presented far less issues with missing/super quiet bits (eg: voice audio) of audio in games.
  3. DbD
    DbD Minimodder
    13 Dec 2007
    The problem with the old rog centurion 7.1 was the cables break internally - too many wires hiding in there - and it wasn't a replaceable cable. That's what I'd want to know this time - is it going to break just outside of warranty on me? Can I replace the cable if it does?
  4. wolfticket
    19 Apr 2008
    Should I buy 7.1 headphones if I only have 2.0 ears?
Tags: Add Tags
