Case Mod - In Progress ASUS ROG-TJ11 Diablo III Edition-Update and Finished.
Discussion in 'Project Logs' started by nhenhophach, 5 Dec 2011.
  1. nhenhophach
    nhenhophach Bit-tech
    16 Aug 2007
    Silverstone TJ11 Diablo III Edition.
    First i show the old case that i will move all hardware to TJ11.( Pics take by HTC phone)
    LIAN LI V1000
    ASUS RAMPAGE II Extreme with EK motherboard block.
    ASUS GTX580 Di CU II with custom block by me:D
    One D5 pump
    Thermaltake 1200W PSU.
    SSD Crucial C300
    Dominator 12GB With EK block.
    Now TJ11 brand new.
    This case i use two Watercooling loops.
    2 Black Ice GTX 280 Radiator.
    I made a chassic to hold 2 RAD. and i call that is unit One. Unit One can easy install and uninstall. Easy take out.
    Tow D5 and RP 450 from Koolance.
  2. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    TJ11 + Diablo 3 = Happy Fun Time
    Can't wait to see how this turns out, Mod On :rock:
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    Ouhhhhh... I hope you get rid of those fugly holes in the sidepanels.
  4. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Nice start! +subscribing, because every thing you touch becomes awesome.
  5. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Will be following this one!
  6. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I watch :)
  7. z3bb0
    z3bb0 What's a Dremel?
    3 Dec 2011
    Sub'd! tj 11 mods are always exciting :)
  8. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Definately one to watch! :thumb:
    But... "ASUS GTX580 Di CU II with custom block by me" ... ME WANNA SEE! :naughty:
  9. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Subbed :thumb:
    What coller theme will you be using?
  10. nhenhophach
    16 Aug 2007
    All fittings is Bitspower 90 Rotary Adapter and SLi Connectors.
    Other work.
  11. Gentleman_Dingo
    30 Aug 2007
    Holy Bitspower.... that is paycheck's worth of fittings.
  12. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    I like what you did with the rads :).
  13. Cheapskate
    13 May 2007
    This should be awesome.
    You made a lot of fans here. :D
  14. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Indeed he has.
    Don't think much of the stock case, in all its grandure i'm looking forward to seeing what becomes of it!
    Keep the updates coming I'm really looking forward to seeing something new you might have instore for us.
    :clap::clap::clap::clap:
  15. nhenhophach
    16 Aug 2007
    Update EK VGA BLOCK
    Just tell about my troble with EK VGA BLOCK. Because this case use 2 ASUS GTX 580 Di CU II. So i oder two block.
    This is what i say. They don't make 2 hole back. So how to SLI connect?:duh::wallbash:
    Back only 10mm so i can't drill 2 hole.
    Not only difficult SLI connect but also difficult for who want set up water loop CPU---------->Chipset Block---------->VGA. Or possible when you accept look very bad.
    [​IMG].:duh:
    But finaly i found way to connect 2 Block together:D.
  16. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    I believe you can still use the EK SLI bridge pieces with those blocks
  17. nhenhophach
    16 Aug 2007
    Back to my work.
    I relace EK RAM waterblock top with new IN and OUT
    The ruler from Bit-tech. Won MOTM( July ).
    I continue use Interconnect plate on this case. And use hard tube.
    Measurement
    The Plate to connect PUMP, RADIATOR and VGA.
    This is all i mean.
    The Reservoirs
    I custom this Reservoirs. Acrylic and Super Glue( CHCL3 with Arcylic you never worry about leak)
    You see it not transparent because i use planers
    Reservoirs is many layer. Connect from 2 PUMP to 2 loop. Sorry my English so i can't explain more.;).
  18. DesertFox
    DesertFox What's a Dremel?
    25 Oct 2004
    Sexy looking build so far!
    Are those 2 RADs going to be enough to cool CPU, Mem, Mobo and 2 GPUs?
    You don't have a sketch or anything to show us what you're planning? Is the "Diablo III Edition" just referring to the colour scheme - red and black?
    Looking forward to some more updates!
  19. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Thats a massive reservoir !
    Awsome!
  20. nhenhophach
    16 Aug 2007
    Yeah. Because i am learning Sketchup:D. So can't show up my planing.
